3 Piece Bathroom Rough In - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-05-2012, 08:37 AM   #1
3 piece bathroom rough in
I brought this house a little over a year ago and I started to develop the basement. I am currently installing the orvx subfloor panels but I want to rough in the bathroom first before installing the panels in the bathroom. The builder has roughed the bathroom for 3 piece but I am not sure what pipe is for which. Attached is the pictures of the bathroom. I believe Hole #1 is for the sink and Hole #2 is for shower but I would like this to be confirmed by others. Thanks!
3 piece bathroom rough in-3-peiece-bathroom.jpg   3 piece bathroom rough in-hole-1.jpg   3 piece bathroom rough in-hole-2.jpg
newfieblue is offline   Reply With Quote
Old 03-05-2012, 07:35 PM   #2
Rewards Points: 636
is there a vent pipe in ceiling "between floor joist a capped pipe "for new plumbing
the one that is larger i think hole 2 might be a backwater valve remove cover or cap and see what is inside of it
the other one "hole one"covered in gravel is just capped off "what size is it" if you use it for tub or shower you will need to add trap and it could also be used to drain sink if plumbed right
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-06-2012, 06:04 AM   #3
There is a vent next to the washer/dryer(just to the right of the picture).
The builder has confirmed hole #2 is a backwater valve and Hole #1 is for the shower.
Old 03-06-2012, 06:13 AM   #4
DIY staff
Rewards Points: 7,174
Need the sizes of those pipes---
Old 03-06-2012, 06:19 AM   #5
Hole #1 is 2" ready for a shower.
Hole #2 is Backwater valve.
Next questions is what do I need to plumb the shower and backwater valve to be able to install the subfloor?
Old 03-06-2012, 06:27 AM   #6
DIY staff
Could you first tell me why a subfloor is going into the bathroom? What will you be using as the finished floor in that bath.
Water---concrete floors and wood subfloors are a bad combination.
Typically. the walls are framed first---shower pan installed--and rough plumbing and electrical--floors after that---but I wonder about the plywood on the concrete--
ben's plumbing (03-06-2012)
Old 03-06-2012, 08:21 AM   #7
I am using the barricade 2X2 panels. Will be studding the wall after. The finished floor will be vinyl.
This subfloor system has insulation under the osb and is designed for basements to deal with the air and water problems.
Old 03-06-2012, 06:32 PM   #8
DIY staff
Sorry,I'm not familiar with that system----I'd be concerned with moisture under the panels --
Old 03-06-2012, 07:23 PM   #9
Rewards Points: 636
i have used the dryloc panels worked good but i like this one better by the looks of it
are you sure it is ok to put walls on top since it is a floating floor
Old 03-08-2012, 04:35 AM   #10
It states on the website that you can screw into the panels and will support a stud wall. If you use tiles you have to fasten the panels around the perimeter and throughout the center.
Basement Bathroom Rough In - A Big OOOOOPS! Beepster Plumbing 8 01-16-2012 08:40 AM
Bathroom layout to fit rough in? bryanl Remodeling 6 09-21-2011 08:02 AM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 10:36 AM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
