3 Neighbor's Replacement Drain Fields On MY Lot....advice? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2012, 07:18 AM   #16
Rewards Points: 3,130
So right. I didn't read your previous post closely enough.
Old 11-18-2012, 06:33 PM   #17
Rewards Points: 1,418
As a point of information, a septic tank whose leach field has failed (or whose outlet has collapsed or is otherwise blocked) behaves like a holding tank.
It is not a good idea to plant trees or large shrubs of any kind on a leach field; the roots will get into and clog the leach lines.
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
What is this thing?? Todd54 Plumbing 10 05-09-2012 05:18 AM
Need advice on replacement bathtub MurphyMan Plumbing 11 04-06-2012 07:39 AM
Scupper drain installation advice needed miamicuse Roofing/Siding 9 02-11-2012 10:59 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
