3 Hole Remodel Plate For Shower/tub - 8"on Center - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2009, 10:47 PM   #1
3 hole remodel plate for shower/tub - 8"on center
Replacing my 3 handle shower/tub faucets, showerhead, spout , etc.....
My old 3 handle shower/tub faucets and 12" on center so I need a plate to extend at least 13". (replacing it with one that is 8" on center, seems to be the standard) I see there are alot of different plates for the single handle shower setup. Anybody have any ideas??
phunam04 is offline   Reply With Quote
Old 02-19-2009, 12:06 AM   #2
Rewards Points: 2,906
So far as I know, 8 inches center to center has always been the rough-in distance between hot and cold water supply pipes to a bathtub faucet, so you're going to have a hard time finding anything that isn't made for 8 inch center to center faucet knobs.
You might consider having something like a piece of coloured plastic (to match your tiling) made up 14 inches wide and 6 inches high. Caulk that to the wall over the holes and then install a standard cover plate over that.
Any place that makes plastic signs would be able to cut you a small piece of coloured opaque plexiglas.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 02-19-2009, 01:39 AM   #3
Thanks, looking to make it look something more than a patch job, I've seen a couple of remodel plates that might and probably would work. Looking for more of a variety at this point.
thanks
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Hollow wood door with hole where the hing plate goes earlc General DIY Discussions 4 07-08-2007 01:21 PM
