3-handle Shower Faucet Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-05-2015, 11:10 PM   #1
Rewards Points: 150
3-handle Shower faucet replacement
Hi,
I have an old 3-handle Price Pfister stem&seat shower faucet that is giving me trouble. I tried the Home Depot Price Pfister remodel kit, but after only 2 months of working okayish, the O-rings kept coming loose and do not seal properly, causing me to want to turn it even more (which led to yesterday). Now, no matter what I try, there is a slow steady stream of water that leaks from the tub spout.
- I tried replacing all of the valve stems, still small leak (hot water)
- Tried replacing the faucet seat on hot water side, broke thread but eventually got one on after trying 3 different seats, still small leak
Since the thread on the seat broke, I want to replace the damn thing. Is there any good 3-handle model to replace it with? I do not want to deal with messing with the tiles. I do have access from the back since it is drywall in the closet. I was thinking of this one..
amazon.com/Pfister-01-8CBC-Three-Handle-Shower-Chrome/dp/B001AHO7P6/ref=pd_bxgy_60_text_y
but it is pretty expensive to buy together with the new valve.
Are there any other options I have, like fixing the existing valve or what not? I'm familiar with soldering and installing new valves as I've done it a couple times before, but I'm not a pro in any sense, so i want to say that would be my last resort. If you guys have any ideas that'd be great.
Thanks in advance,
Mike
mikemark8808 is offline   Reply With Quote
Old 09-06-2015, 08:06 AM   #2
Rewards Points: 1,046
You actually have problems your not aware of. Current plumbing code requires you use a pressure balance temperature control valve as a replacement. No 3 handle meets that requirement.
Heres what you need
http://www.faucet-warehouse.com/Moen...FQoTHwod_S0OMQ
http://www.build.com/moen-tl183nh-tu...150906130555:s
This valve eliminates the flush the toilet get scalded issue.
The Following User Says Thank You to Ghostmaker For This Useful Post:
oh'mike (09-06-2015)
Old 09-06-2015, 08:48 AM   #3
Rewards Points: 150
Hi Ghost,
Thanks, so you mean switch to a 1 handle? I was thinking about it last night and thought it wouldn't be too bad.. Rearranging the tiles and cutting the bad ones out.. How would I find some matching tiles just in case?
Old 09-06-2015, 09:46 AM   #4
Rewards Points: 300
They make over sized covers for this -
http://www.homedepot.com/p/MOEN-Remo...20BN/203466049
tribe_fan is offline   Reply With Quote
Old 09-06-2015, 08:29 PM   #5
One link is for the huge cover the other for the faucet.
Old 09-06-2015, 08:39 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
and yours is $17 cheaper!!!!
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
pressure and shower faucet rob613 Plumbing 2 04-18-2013 12:07 PM
Help with Replacing a Shower Faucet adodd87 Plumbing 17 01-21-2012 09:21 PM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 03:27 PM
Trouble replacing 2 handle shower levers matt7125 Kitchen & Bath Remodeling 2 12-02-2009 07:55 AM
