3 Handle Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2007, 09:01 AM   #1
3 handle shower
i have just replaced the handles in my three handle shower tub (cold, hot, diverter). i have a price pfiser but could not find a model number on the housing so i removed the stems and replaced with a universal price pfiser shower tub replacement system...hooked up according to directions...it works well but when i have the water on a high pressure i get a little leak from the cold water handle...i have taken off and reattached and the problem is still there...it is only a small amount of water, but i think it leaks down inside the wall, so i want this fixed...what should i do.
epolgar is offline   Reply With Quote
Old 08-13-2007, 09:02 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
See if tightening up the packing nut behind the handle will stop the leakage.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 02:58 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 12:01 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 10:33 AM
Installing a New shower facuet... BDPNA Plumbing 8 01-18-2007 08:23 AM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 06:17 PM
