3" Copper House Main Bath/Toilet Drain Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2010, 12:26 PM   #1
Rewards Points: 258
About 8' long with 12 sweat joints do decouple. The copper sections have become quite thin over 46 years. The brass elbows and T's seam fine.
My question is can two guys using hardware store mapp gas generate enough heat to separate the joints and remove the old sections? Then generate enough heat to sweat in the new sections?
I have considered going to PVC. My concern is I would still need some good copper to couple up to and there is none. I would still need to use heat to replace some bad copper.
A copper penny for your thoughts on this. Thanks
Docfletcher is offline   Reply With Quote
Old 02-04-2010, 01:19 PM   #2
47_47's Avatar
Rewards Points: 44
I was in the same boat, but I could cut back to solid and used a fernco to connect new PVC to copper. I cut it out with a sawzall, scrapped the copper and brass. Use an acetylene tank to sweat this large copper.
47_47 is offline   Reply With Quote
Old 02-04-2010, 01:51 PM   #3
Rewards Points: 258
Yeah, acetylene I might have to use. I just stupidly pushed on it with a screwdriver, it went right through. patched it with a little dab of polycarbonate.
Old 02-04-2010, 09:34 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
a good turbo torch extreme with mapp gas will solder 3" without too much trouble
plummen is offline   Reply With Quote
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
Main Drain Assembley--What is This? wsuswim147 Plumbing 5 03-20-2009 06:41 PM
90 degree turn in horizontal 3" main drain wildbilly Plumbing 2 03-14-2009 06:52 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 11:29 PM
