Old 02-19-2011, 03:45 PM   #1
3" ABS toilet drain - height change - trap arm
Ever mindful of the need to avoid siphoning the p-trap under my new shower, I think the maximum developed trap arm for my upstream 3" toilet drain is 12'. If that is the case, I have a 3" height adjustment to do as the new location crosses over a 4" line that is that much higher. Does making a height adjustment with two 22 1/2" ells affect the allowable length? The toilet is now 6' from the 2" vent. So, it would go about 2' from the toilet at 1/4" per foot, drop about 3", then continue into the existing drain, again at the approved slope. Does that make sense? Is it allowable under Canadian or other codes? Does there need to be something placed between the ABS pipes or can they rest one on top of the other?
Thanks in advance for any assistance.
Rousifier is offline   Reply With Quote
Old 02-19-2011, 11:11 PM   #2
Doing it myself
Alan's Avatar
Not sure about your jurisdiction, but a 3" trap arm out here maxes out at 6', and your vent has to come off the top of the trap arm, meaning any offsets vertically between the vent and the trap are not allowed, and horizontal offsets up to 135* ARE allowed.
Journeyman Plumber
Old 02-19-2011, 11:41 PM   #3
Thanks, Alan, I really appreciate the help.
R.
Toilet Flange Inside or Outside Drain Pipe? sledged Plumbing 23 01-18-2012 01:18 PM
Elevate the toilet to run the drain? hohadcr Plumbing 16 03-29-2010 10:52 AM
Plumber's Question..about Toilet drain K.M.G Plumbing 4 09-23-2009 03:06 PM
how many turns is acceptable on toilet drain moegumble Plumbing 6 08-13-2009 11:28 PM
shower drain vs tub drain--connected to toilet???? mandalala Plumbing 2 06-24-2009 03:00 PM
