3/8" Pipe Insulation - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-06-2010, 10:05 AM   #1
3/8" pipe insulation
I am interested in insulating some hot water pipes that
Asbestos was removed from. 3/4 inch ; brass in an old brownstone.
Is 3/8 thick insulation thick enough? It has an
r factor of 2.4. If not, what should I use.
10235bill is offline   Reply With Quote
Old 10-06-2010, 02:52 PM   #2
Rewards Points: 590
I think 3/4" foam is also available. The R value is a little over 3.
operagost is offline   Reply With Quote
Pipe insulation: Foam, Rubber, Other? IckesTheSane Plumbing 40 03-21-2016 07:57 PM
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 02:53 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Steam Pipe insulation. Any gain for insulating return pipes? slowjo HVAC 17 02-19-2012 09:53 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
