3/4" Vs 1" Pvc - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-10-2010, 11:21 AM   #1
3/4" vs 1" pvc
I am running a water line from my house to a hydrant in a shed, the distance is about 250'. Should I use 3/4 or 1 pvc?
rlaurent79 is offline   Reply With Quote
Old 08-10-2010, 10:12 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If you want to POSSIBLY tap anything else into it in the future it isn't a bad idea to upsize.
Journeyman Plumber
Old 08-10-2010, 10:48 PM   #3
Would there be any see able flow difference?
Old 08-10-2010, 11:31 PM   #4
Doing it myself
Alan's Avatar
If you're just using a single hose bibb on it for now, you won't notice any difference, but depending on what you may or may not tap into it in the future, you may or may not notice.
Price the difference between 3/4" and 1"
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
rlaurent79 (08-11-2010)
Old 08-11-2010, 01:32 AM   #5
Rewards Points: 352
because of friction loss over a 250' run, go bigger
plumberinlaw is offline   Reply With Quote
Old 08-11-2010, 09:42 AM   #6
Owner
LateralConcepts's Avatar
I would use 1" poly rather than PVC. With PVC in a 250' run you'll have at least 25 joints. That's a lot to bury.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
3/4" hardwood over 3/4" T&G subfloor benjamincall Flooring 16 03-18-2010 11:46 PM
Can I go up from 3/4" metal gas pipe to a 1" and then back down? Philip_Soldat Plumbing 3 11-09-2009 10:47 AM
1" copper vs 3/4" copper Plumbvoltage Plumbing 3 09-04-2009 04:11 PM
3/4" Partical board underlayment OK for new 3/4" oak? housefixin Flooring 4 02-23-2008 05:36 PM
EMT fill - 2 x 3/4" or 1x 1"? IvoryRing Electrical 12 05-05-2006 11:51 AM
