3/4 " To Small For Main - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-12-2008, 10:55 PM   #1
3/4 " to small for main
I am doing a repipe, what a pain!!!! I couldn't find 1" flex to connect my water softener with and didn't want to hard pipe with no flex to the softener. So I am basically making my whole house go through 3/4" pipe. However, the softener itself really isn't 1" inside anyway, it is about 27/32, a little less than 7/8", and it has a little cross brace inside of that. So, what about 3/4 for the whole house, it should still be better than the old galvy that I have.......what a pain
fast380 is offline   Reply With Quote
Old 01-12-2008, 11:45 PM   #2
Send a message via AIM to Marlin
Go read the answers in your last posting of the same question...
Marlin is offline   Reply With Quote
Old 01-13-2008, 11:38 PM   #3
Master Plumber
Rewards Points: 150
The size of your main has to do with the incoming pressure, the size of the water meter, distance and rise of pipe and the number of fixture units in your house.
jpplumber is offline   Reply With Quote
Old 01-14-2008, 09:08 PM   #4
Journeyman Plumber
Ron The Plumber's Avatar
Yes you have to know the codes in your area to decide how large the water service needs to be, we always run 1" even if it's not needed.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 01-14-2008, 09:56 PM   #5
Home Remodeler
Rewards Points: 164
Most homes in our area are 3/4 inch and then 1/2 inch to the sinks etc. I would use 1 inch to all the 1/2. With 3/4 inch you may get lower flow and when you flush the toilet the shower or faucet will change temp or will cause lower flow. Just my opinion.
mikey48 is offline   Reply With Quote
Can a DIY build a small in-ground swimming pool? zel General DIY Discussions 14 06-15-2013 10:42 AM
Small engine repair tripower Tools 2 07-09-2009 04:28 AM
Best way to crimp small disconnects Alpha Crow Electrical 15 10-13-2007 09:04 AM
Number of circuits needed for a small kitchen? All responses welcome! alexz Electrical 5 04-07-2007 11:38 AM
Curved Small Stage jalaux Carpentry 1 07-09-2006 10:57 PM
