3/4" Pex - Is There A Trick? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-13-2009, 09:40 PM   #1
WaldenL's Avatar
Rewards Points: 268
3/4" Pex - Is there a trick?
I love pex. I've used it several time w/great success. Nice long runs, no connectors to worry about, what could be better? However, I've always used 1/2" pex. I've found 1/2" pex to be about as hard to bend to my will as 12ga wire... that is rather simple.
I now realize that there's a reason for the manifolds everyone uses w/pex. It has nothing to do with home runs or a single spot for all the valves, it's so no one has to use 3/4" pex! I surrender! Maybe Bill Bixby (when he's angry!) could do it, but I sure as hell can't make nice tight turns with 3/4" pex.
Any tricks?
WaldenL is offline   Reply With Quote
Old 10-13-2009, 11:54 PM   #2
Civil Engineer
Rewards Points: 4,520
You don't try to bend 3/4 inch into a tight turn, you use a 90 degree fitting.
Old 10-14-2009, 11:46 PM   #3
WaldenL's Avatar
Rewards Points: 268
I'm discovering that. New crimp tool and all. :-) Still, 1/2" is much nicer than 3/4". I can't imagine 1"!
Old 10-15-2009, 12:30 PM   #4
Rewards Points: 392
Are you using the 90 degree radius fittings that clip on the pex? They help, but it is still hard to bend it into that radius to fit the fitting.
Another trick is to heat the fat pex up using a blow drier, it makes it softer. When it cools down it hardens back up. Make sure you heat it uniform or you'll kink it.
zootjeff is offline   Reply With Quote
Old 10-15-2009, 12:43 PM   #5
WaldenL's Avatar
Rewards Points: 268
Got some heating water going through 3/4" last night. Amazing how much more pliable it is when warm. I'll give the blow drier a shot.
As for the 90* radius fittings that clip on... what 90* radius fittings? The only fittings I know of are the one where you cut the pex, something like the below, but I don't think that's what you mean.
Old 10-15-2009, 06:05 PM   #6
Rewards Points: 392
http://www.pexsupply.com/Wirsbo-Upon...port-2129000-p
3/4" Plastic Bend Support
SKU:A5150750
Brand: Wirsbo (Uponor)
From pexsupply.com under installation parts.
Old 10-15-2009, 06:07 PM   #7
WaldenL's Avatar
Rewards Points: 268
Cool. Thanks.
Old 10-15-2009, 06:32 PM   #8
Rewards Points: 392
Cool. Thanks.
Yaa, the bend supports are nice, they allow you to mount them or you can cut off the tab for mounting it. They keep the pressure drops to a min and less water hammer as the water doesn't have to change direction abruptly.
JASCO Paint remover - what's the trick? cody21 Painting 7 11-19-2010 06:42 PM
trick a newby concocted fauer Plumbing 1 09-02-2008 11:26 PM
3/4" Partical board underlayment OK for new 3/4" oak? housefixin Flooring 4 02-23-2008 05:36 PM
3/4" Gravel on Sloped Driveway not locking - help? WynsWrld98 Landscaping & Lawn Care 7 10-17-2007 12:02 PM
Tub Drain Install - What's The Trick? Ricky D Plumbing 2 06-09-2007 07:22 AM
