Old 06-10-2011, 10:25 AM   #1
3/4" copper from bsmt to 2nd flr attic
How do you drill holes, thru fire stops/headers from the bsmt or attic, when they are 10 ft away in the walls?
I need to run a water line from the bsmt, up to my attic. The area around the soil pipe is too crowded, and the laundry chute/chimney is also blocked.
So I need to make a new run up.
Any idea's on how this is done?
thanks all !!
-Mark
mlitt55 is offline   Reply With Quote
Old 06-10-2011, 11:59 AM   #2
You'll have to cut out the drywall to drill the holes. I don't see any other way around it.
Stanchek is offline   Reply With Quote
Old 06-10-2011, 11:58 PM   #3
Doing it myself
Alan's Avatar
The other option is to leave it exposed, mount it to existing sheetrock and build a small soffit around it.
Journeyman Plumber
Old 06-12-2011, 10:43 AM   #4
Just drill the holes through the fire stops and put a sleeve in.
When you have completed the job buy fire stop caulking and just caulk around the pipes real good. The caulking is approved at high temps.
COLDIRON is online now   Reply With Quote
Attic venting questions lemmy Roofing 36 05-28-2011 09:14 PM
Can I mount a window A/C into the wall, exhausting to the attic? Greg2230 HVAC 2 06-01-2010 09:56 PM
Copper pipe size question greymous Plumbing 18 01-30-2009 05:02 PM
Attic moisture Carstonio Roofing 14 01-29-2009 12:35 PM
PVC Conduit use in Attic? What is accepted Ambient scatkins Electrical 2 12-03-2008 02:07 PM
