2ND Story Addition Rough In Drwgs - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-13-2013, 07:25 PM   #1
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,158
I'm working on a 2nd story addition with a full tear out of the first floor as well.
Please pick apart my piping design.
Sorry about the PDF's. I tried to make up JPEG's but they just don't come too clear from the CAD drawings.
I've been working on some plumbing drawings recently.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 10-13-2013, 08:07 PM   #2
Rewards Points: 1,948
Sorry I can't help I only know IPC US code.
Old 10-13-2013, 08:33 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 664
Same here- I work with UPC
One thing on the drawings though- use a single line/dashed line to show pipes.
That's what we're used to
Old 10-14-2013, 12:34 PM   #4
123pugsy's Avatar
Thanks.
OK, maybe break down a part here and there.
The Ontario Building Code states:
7.5.2.1. Wet Venting
(1) A soil or waste pipe may serve as a wet vent provided that,
(a) the hydraulic load is in accordance with Table 7.5.8.1.,
(b) the number of wet vented water closets does not exceed 2,
(c) when 2 water closets are installed, they are connected at the same level to a vertical
part of the stack by means of a double fitting in accordance with Table 7.2.4.5.,
(d) the water closets are installed downstream of all other fixtures,
Does this downstream apply if I install a separate vent as shown? I was going to use a 2" wet vent from the vanity where I show the w/c vent in blue but I read this and changed it.
2-Story Addition...Trials and Tribulations ddawg16 Project Showcase 414 01-19-2017 04:37 AM
100 year old story and half to 2 story PROJECT brandenJ Building & Construction 5 06-07-2012 10:47 AM
2 story, 3 story, or a basement? reveriereptile Building & Construction 13 10-10-2011 05:30 PM
second story addition JayG Building & Construction 9 02-26-2010 08:35 AM
second story addition fidel427 Building & Construction 1 08-13-2009 09:11 PM
