2nd Floor Sewage Smell - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-02-2013, 01:26 PM   #1
Smile
2nd Floor Sewage smell
Hi folks
I was just appointed head of facilities at a brand new 19 million dollar building.
I do have to do some janitorial work as well. so Im pretty busy. I have been smelling a very foul smell coming from the 2nd floor, mens room floor drain. The building has a Basement, 1st floor second floor, roof which has a vent. Their are 4 wall mounted urinals 6 toilets in 4 bathrooms, each has a floor drain. The only bathroom that smell real bad is the 2nd floor mens. Why??? I was told to pour water down it to stop the gases from coming up. It helped a lot. Why does this happen shouldn't the circuit be self supplied with a water source. I have the prints, did they mis a p trap
Thank a 1,000,000
JodyG
jodyg is offline   Reply With Quote
Old 03-02-2013, 01:45 PM   #2
bbo
if there is no water going down the drain ever, the trap will eventually dry up and sewer gasses will escape.
if you poured water down and it helped, most likely the trap had been dry.
bbo is offline   Reply With Quote
Old 03-02-2013, 03:48 PM   #3
most newer buildings required trap primers on floor drains. they run a little water into the trap when a sink is used. is this building occupied 100%?
Old 03-02-2013, 04:13 PM   #4
2nd floor smell
Thank you for your reply
This building is a bus depot. where many people use the First floor bathrooms. unlike the 2nd floor where it get used very little, but does get used. This room is for our bus drivers. The room that smells is the mens room, or did smell, I poured water down it. So this should get a feed from the sinks??? If so these sinks have an electric eye to shut off. and the water pressure is very light. So this might have a primer hooked up. This I should see in the prints.
best to you
jody
Old 03-02-2013, 04:33 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 436
Some drawings will show trap primers to be installed- may have to look at detail drawings. If the building is new- they should be there. Pretty much code required now days.
Check under the lavs for a small 3/8" tube connected to the tailpiece. also look at the flush valves on the toilets for the same tube. Usually only one fixture per bathroom will have the primer tube. Also look for an access panel on the plumbing wall. Sometimes a trap primer valve is used rather then feeding off a fixture- they are easily calibrated.
Old 03-02-2013, 05:38 PM   #6
Rewards Points: 1,766
best to you
jody
Trap primer installs would depend on the plumbing code at the time and your plumbing inspector opinion. At one time the belief was that when the floor was mopped enough water would get into the trap to maintain the seal. But now a days folks just damp mob so nothing gets into the trap. Just have your janitor dump water down that floor drain on a monthly basis.
Tags
sewage , smell , vent
Smell coming from all floor registers. John_W HVAC 10 08-07-2015 07:42 PM
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 01:57 PM
Smell when boiler runs? dave12345 HVAC 13 11-11-2013 09:08 AM
Sewer smell in basement (with pictures) cne24 Plumbing 4 02-11-2013 07:37 PM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
