22.5 Degree Elbow Fitting - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2013, 02:39 PM   #1
Exclamation
22.5 degree elbow fitting
Does anyone know where I can find a 22.5 degree, copper or any metal, elbow fitting. I need this in ether a 3/8 in or 1/2 in. Thank You.
spalacios is offline   Reply With Quote
Old 03-08-2013, 03:43 PM   #2
Can I ask why? Never used one in copper, but they have to exist, right?
paintdrying is offline   Reply With Quote
Old 03-08-2013, 05:41 PM   #3
response
I need to repair a fiberglass tent pole and cannot find a replacement ferrule in that size and angle.
Old 03-08-2013, 05:52 PM   #4
Roofmaster
Rewards Points: 2,172
Why would a tent pole be at an angle? Just Curious. Can you use back to back lag eyebolts, a bolt, two fender washers, and a self locking nut? Maybe you can find an umbrella knuckle, like they use on a big umbrealla for a picnic table?
Old 03-08-2013, 05:59 PM   #5
The ferrule has to be bent because of the shape of the canopy that the fiberglass poles support.
Old 03-08-2013, 06:02 PM   #6
Rewards Points: 12,876
Any box store or real plumbing supply should have them.
There's dozen of places on the net stocking them. But's seen them at Lowes and HD.
Old 03-08-2013, 06:04 PM   #7
Ive been checking online for over an hour and have only found at closest a 45 degree angle one. I also checked the websites of Lowes and HD nd they dont have it either.
Old 03-08-2013, 06:09 PM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 984
never seen a 22 in copper. you can make a swing joint may look funny but will give you the degrees you need.
swing joint regular 90 coupled with street 90.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-08-2013, 06:13 PM   #9
Sorry, I wasnt very clear, it does NOT have to be copper. It can be aluminum or steel as well, i just thought copper would be more common. And thank you for all of your help.
Old 03-08-2013, 06:14 PM   #10
No box store list everything they sell on there web site.
Got to get out of the chair and go get it.
http://www.bing.com/search?q=22-1%2F...sp=-1&qs=n&sk=
paintdrying (03-08-2013)
Old 03-08-2013, 06:18 PM   #11
I can only look online for now, too much snow.
Old 03-08-2013, 06:24 PM   #12
Roofmaster
WHy dont you just buy soft copper and bend it yourself with a spring tubing bender? Is this one of those Mr. Rogers umbrella tents? I thought the ferrules were straight, and the rods bent. How about some rubber tubing and a couple of hose clamps?
Old 03-08-2013, 06:25 PM   #13
Plumber
TheEplumber's Avatar
Rewards Points: 354
I've never seen a 22 in less then 1 1/4"
Thought about using soft copper tubing and bending it?
Old 03-08-2013, 06:32 PM   #14
I thought of that, but i dont think that would work, the poles are under alot of tension and I'm afraid that another storm or high winds might just bend it again. And no, it is not even a tent, it is a sports netting system.
Old 03-08-2013, 07:55 PM   #15
Roofmaster
Maybe you can be a bit less cryptic and tell up what you are actually trying to do. This is getting like a game show where you give us hints and we try to figure out what you are trying to do. There are a lot of smart people here at your disposal, but we need the facts, Jack.
The Following User Says Thank You to jagans For This Useful Post:
Javiles (03-09-2013)
Tags
22.5 degree , copper , elbow fitting , plumbing
Need condensate drain elbow fitting for room AC raylo32 HVAC 22 05-23-2012 07:42 AM
radiator union elbow and valve nipple fitting amakarevic Plumbing 1 11-12-2011 03:30 PM
tool for fitting radiator union elbow amakarevic Plumbing 1 09-22-2011 07:52 PM
22.5 degree baseboard cuts Jefferybro Carpentry 1 08-23-2011 02:49 PM
4 inch 90 degree PVC elbow w/2 inch heel inlet amakarevic Plumbing 5 07-27-2007 07:59 PM
