200 Psi Poly Pipe Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-15-2012, 11:59 AM   #1
200 psi poly pipe repair
I recently cut through my 1" 200 psi poly pipe wich feeds to the back yard and is under pressure all thetime and I tried to find cinch clamps for it and unabel to use the regular 1" Cinch Clamp. What size cinch clamp do I need and can I use a standard inch coupler with barbs to repir this line.
twmackey is offline   Reply With Quote
Old 04-15-2012, 03:51 PM   #2
DIY staff
Rewards Points: 7,174
200 PSI? that's an unusually high pressure for water---
I'll wait for a licenced plumber to check this one--Mike---
Old 04-15-2012, 04:43 PM   #3
some water pressures have reported over 112 psi for our waterdistict. the poly was put in insted of PVC pipe. A regular 1 inch cinch clamp will not fit over a 1 inch 200 psi poly because of the thickness of it.
Old 04-15-2012, 05:03 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 802
Use a barbed insert and hose clamps- standard procedure on 200 psi pipe. May need a little torch heat to get the insert in
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (04-15-2012), jaydevries (04-15-2012)
Old 04-15-2012, 09:27 PM   #5
Rewards Points: 582
not sure of the name but they make a repair cuppling for 200 psi pipe..consist of a barbed fitting a metal hold ring and a o ring gasket...works very well...sorry can't remember the name..they are white pvc fittings...
Old 04-15-2012, 09:36 PM   #6
Plumber
Rewards Points: 802
Do me a favor and find out at your convenience. Is it like a Ford or McDonald fitting only plastic?
Old 04-15-2012, 10:37 PM   #7
I've used a brass compression repair coupling in high pressure situations with great success.
VIPlumber is offline   Reply With Quote
Question about copper pipe agroom Plumbing 3 10-27-2011 02:18 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
metal pipe thread repair? digitalknoll Plumbing 14 03-30-2010 09:06 AM
Poly pipe couplings rtoni Plumbing 3 06-15-2009 09:53 PM
Help needed 3/4 poly pipe joining sections. TomClarkInLubbock Landscaping & Lawn Care 3 08-13-2007 06:44 AM
