20 Year Old Culligan Water Softener Has A Telephone Symbol In The Display - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2011, 02:45 PM   #1
20 year old culligan water softener has a telephone symbol in the display
20 year old culligan water softener has a telephone symbol in the display, it does not function correctly, when it goes to regen it defaults back to tele symbol, even after i reset it??
please nay suggestions to help fix the issue, besides calling culligan itself???
the unit starts the regen process, and about 15 minutes later hits the telephone symbol??
what to do???
dteck is offline   Reply With Quote
Old 08-03-2011, 09:35 PM   #2
Water Treatment
Rewards Points: 850
Sounds like the control board has failed, and may either need to be replaced or it might be able to take a hard reset and then programed again to the settings that you have been using.
More information on the system in question and a photo is most likely the best way to getting the information needed.
I have come across a book that has the steps on the hard reset of the computer.... but would need to know which one you have so that the right steps are taken.
Akpsdvan is offline   Reply With Quote
Old 08-07-2011, 12:53 PM   #3
more details
i have a culligan premier 12'
aqua sensor
model # 01010750
it also is discharging water all the time and i can not seem to stop it???
Old 08-07-2011, 12:59 PM   #4
Experienced
Jackofall1's Avatar
If you are fairly capable I would bet that the drive motor on the valve assembly is failing either due to the valve assembly needing to be rebuilt (new seals put in) or just a tired motor.
Look the model up on line, if you don't have the manual, and order the parts from Culligan including the motor, should cost about $30 and rebuild the unit.
Its really not that difficult to do.
Mark
Old 08-07-2011, 01:21 PM   #5
Water Treatment
Rewards Points: 850
I did not know that one could order culligan parts on line. I did know that one culligan dealer has a part of two listed but that was it.
Is the motor 120 volt or 24volt?
Main seal pack assembly most likely is going to need replacing, the age most likely has the piston no longer any good and that the middle seals are gone.
Old 08-07-2011, 01:35 PM   #6
Experienced
Jackofall1's Avatar
I don't know exactly about Culligan, I did rebuild my Rainsoft, and ordered the parts from the distributor, I ordered all the seals and motor, took about an hour or so to rebuild.
I called a service rep and they were more than willing to share what would typically go wrong with them.
PS if you they no longer have the seals, you can always take it apart and go to the local hardware and match the orings, most hardwares have a good assortment of orings. The motor is a different story.....good luck.
Lubricate the orings with vasoline when doing the assembly, check for any ridges in the valve body camber and hone or lightly sand with emery cloth as needed. The pistons are just a plunger with orings on it, which slide in a chamber, just need to replace the orings.
I believe the motor was 24V as there is a transformer on the power supply to the unit, at least mine did and I would bet yours does to.
The motor drive a series of cam which in turn depress the valve assemblies for the various stages of regeneration.
Mark
Old 08-07-2011, 02:04 PM   #7
culligan
thank you
how can i stop the drainage from occuring
the system constantly drains no matter what i do???
Old 08-07-2011, 02:08 PM   #8
Water Treatment
Rewards Points: 850
Move the red blue piston to by pass for now til the system is fixed, the water will be untreated til then.
Old 08-07-2011, 02:08 PM   #9
is there a way to reset it to stop what it is doing and stop draining water from the drainage hose??
Old 08-07-2011, 02:09 PM   #10
in bypass mode now
water still draining??
Old 08-07-2011, 02:10 PM   #11
Water Treatment
Rewards Points: 850
With the seals in that one area torn it is going to be hard to stop the water short of either replacing or putting the bypass piston into bypass for now til repairs are made.
There will be some water going to the drain til there is no more pressure in the softener media tank, once there is no pressure the water should stop going to the drain, that is unless the bypass seals fail... then that piston will need repair as well.
Old 08-07-2011, 02:14 PM   #12
umm i have it in bypass since last night still draining water???
Old 08-07-2011, 02:22 PM   #13
Water Treatment
Rewards Points: 850
You might try pushing the bypass back and forth a few times and try to get the red part all the way to the brass valve, it could be that either the piston is not seating all the way or that the o rings on the piston have torn because of the lack of movement over the years.
Old 08-07-2011, 02:24 PM   #14
i donot have the push type
levers up is bypass
down is service
Old 08-07-2011, 02:26 PM   #15
Water Treatment
Rewards Points: 850
levers up is bypass
down is service
Either way they are for the most part the same, there are o rings on the one that you have that may not be good any more.
Have you tried moving that lever up and down to the fully seated open and closed a few times?
Any chance or either posting some photos or emailing some photos?
Culligan water softener problem hmsmayda Plumbing 1 02-01-2011 08:39 PM
Culligan Medalist Water Softener will not regenerate Joyce4898 Plumbing 1 01-09-2011 10:27 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Culligan Mark 89, water SALTY after regen. Lehouillier Plumbing 11 04-11-2010 07:47 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
