2 Yr Old Gas Water Heater Not Lighting Up, Signal Light On - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-16-2013, 12:28 AM   #1
Rewards Points: 1,062
Question
2 yr old gas water heater not lighting up, signal light on
I have a Whirlpool 40 gal gas water heater that I got around 2 years ago.
Doing dishes tonight, I noticed the warm water was getting colder. When I went to check the water heater, the signal light which indicates proper function was off. It had been continuously on since I got it.
I first tried reigniting it following the instructions on the heater: turned the little knob to PILOT and kept clicking the igniter button once every second but the light wouldn't come on.
Then I thought that some weird little object could be stuck in between the gas pipe shutoff valve and the heater so I disconnected the yellow flex connector at the heater and confirmed that that was not the problem -- the gas flow was normal.
When I reconnected the pipe, I went ahead and tried reigniting the pilot, the same as before. This time it worked after a few tries but the heater would actually not start heating water. In other words, even though the water in it is cold (I tried releasing a few drops from the drain valve at the bottom), the flames don't light up and the heater remains cold. So I have no hot water now.
The little signal light is not powered by external electrical supply but instead there is something inside the heater that generates the low voltage out of I guess burning gas. So evidently, the pilot flame IS burning inside the heater but the burner won't come on.
What could be the reason of this malfunction?
The Following User Says Thank You to amakarevic For This Useful Post:
camorris (04-02-2014)
Old 12-16-2013, 07:00 AM   #2
Rewards Points: 582
sorry to say but those whirlpool heaters from lowes are junk.....anyway.. did you remember to turn pilot knob to the on position after lighting it...if so tap gently on the control see if it fires..... if not check the little safety switch by burnner assy may have tripped.....ben sr
Old 12-16-2013, 08:37 AM   #3
Yes, I did turn it to ON. What kind of water heaters are better than Whirlpool?
Old 12-16-2013, 01:43 PM   #4
further research suggests it may be the thermocouple...
Old 12-16-2013, 06:04 PM   #5
Rewards Points: 582
is the pilot light comming on then going off when you release button...or is it not lighting at all...if its lighting then going off yes it could be thermocuppler ...if pilot wont light ...then it could be ignitor not working ..or plugged pilot tube..or bad valve.....i thing those heaters have a thermocuppler with reversed threads ..which means a normal over the counter thermocuppler wont work...but dont know if that was changed....ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
amakarevic (12-16-2013)
Old 12-16-2013, 07:09 PM   #6
Rewards Points: 1,294
I believe the left hand thermocouple thread issue was solved several years ago with a class action lawsuit. doesn't guarantee it went away though.
Several years ago we ran into several bad gas valves on water heaters. We tried all the usual fixes...thermocouples, clean pilots etc. Turns out we had to replace the gas valve itself. These were all heaters from big box type stores. We got to the point whenever we came across one we would pull the serial # and call for warrantee replacement of the valve. We replaced all but one of them at some time within a year of getting the replacement
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
Old 12-16-2013, 11:30 PM   #7
Turns out my heater doesn't use the same kind of thermocouple I got (coiled bendable copper tube with some terminals at the ends) but just something that looks like gauge 22 or 24 wires.
2 yr old gas water heater not lighting up, signal light on-forumrunner_20131216_233021.jpg
2 yr old gas water heater not lighting up, signal light on-forumrunner_20131216_233051.jpg
Old 12-17-2013, 06:41 AM   #8
DIY staff
Rewards Points: 7,174
If you call up their customer service,they might send you a new burner unit---in the past,they would only give the parts to a licensed plumber--but that may have changed---
This is the reason I always suggest buying a water heater from a local plumbing supply house---they stock the parts for what they sell.
Bradford White--AO Smith are the brands carried by my local supply house.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
amakarevic (12-17-2013), jmon (12-17-2013)
Old 12-17-2013, 08:45 AM   #9
Rewards Points: 228
Sears Kenmore is the same way. You have to purchased the entire burner assembly to fix a thermocouple problem. The 6 dollar over the counter thermocouples won't work. Ridiculous. No wonder they were sued. Being how it's only 2 years old, they may send you a new one for free, as mike has suggested. May be worth the call to save a little money.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
Old 12-17-2013, 12:12 PM   #10
I called them and they said my heater doesn't use a thermoCOUPLE but a thermoPILE and they will send it to me, charging only for S&H
The Following 2 Users Say Thank You to amakarevic For This Useful Post:
camorris (04-02-2014), jmon (12-17-2013)
Old 12-17-2013, 12:25 PM   #11
Rewards Points: 228
That's great. Glad everything worked out for you. Thanks for sharing your experience, it may help someone else.
The Following 2 Users Say Thank You to jmon For This Useful Post:
amakarevic (12-17-2013), camorris (04-02-2014)
Old 12-17-2013, 12:34 PM   #12
we're yet to see if it works out. will keep you posted. thanks for chiming in.
jmon (12-17-2013), oh'mike (12-18-2013)
Old 12-17-2013, 05:33 PM   #13
Master Plumber
Benplumbing's Avatar
The days of changing out just a thermal couple are over..now its either a Pilot Assembly, thermal pile, or Hot Surface Ignighter.
Benplumbing is offline   Reply With Quote
The Following 2 Users Say Thank You to Benplumbing For This Useful Post:
Old 12-17-2013, 08:15 PM   #14
Rewards Points: 1,770
Remember to thank the congress for the explosion proof hot water tank.....
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 12-17-2013, 08:37 PM   #15
...and they said you can't legislate stupid. Reminds me of the quote I may have read on this forum.
"The trouble with stupid people is there is nothing that eats them"
Tags
gas boiler won't light , water heater
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 07:03 PM
Water heater won't light Ronne28 Plumbing 5 02-21-2013 05:58 PM
Water heater pilot light is lit, but burner won't light jawest Plumbing 1 01-18-2013 10:13 AM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
Pilot Light Won't Stay Lit on Water Heater jdolan HVAC 4 07-23-2010 05:42 PM
