2 Water Heater Tanks Parallel Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2014, 09:10 PM   #16
Rewards Points: 2,108
I hate to break it to you but there is no way that will end up having both tanks fire closely together in time. One will end up drawing down first while the other sets there looking stupid. Manufactures make a manifold for a parallel system but even those with one small flaw cause uneven use of the two tanks. The last in first out is totally not dependent on the piping materials.
Old 05-10-2014, 09:35 PM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 904
Originally Posted by dumbengineer View Post
what is the best/easiest way to support those pipe.
can i buy some plastic T post at home depot that i can screw at the base.
i don't have carpentry equipments to do a wood T post.
i saw this at home depot but the price is too much.. anything cheaper?
Suspend some plumbers tape or 1x material from the joists above to takesome stress of the pipe. Should only run a few bucks
Water Heater Electrical Question Twister Electrical 25 07-09-2014 07:18 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
