2 Sump Pumps To 1 Discharge - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-13-2010, 01:06 PM   #1
2 Sump pumps to 1 discharge
Both sumps are 1 1/2 '' reduced to 1 1/4" with check valves on each.
The discharge is 1 1/4", can I tee it and run both pumps at the same time?
The discharge runs about 100' to ditch.
Mark
crcorn is offline   Reply With Quote
Old 06-13-2010, 05:33 PM   #2
Rewards Points: 1,514
The sump pump instructions recommend a certain pipe diameter. To run two pumps into the same pipe the diameter has to be at least 1-1/2 times that.
Old 06-14-2010, 07:21 AM   #3
If its a duplex system, (2 pumps in the same pit) is it pretty common to tie both into one discharge line the same size since they operate on a lead, lag configuration. Rarely both pumps operate at the same time on a duplex system. Now, if you have two totally seperate pumps in different pits and if they do operate at the same time, you want to upsize the discharge line so it can handle the flow from both pumps if they operate together, I would suggest a 2" pipe here. If you don't the pumps will have to work much harder to pump the same volume and they will fight against each other due to the restricted flow, and your GPM will go down about 30%. It will work, but the effeciency will be reduced.
The Engineer is offline   Reply With Quote
Old 06-14-2010, 08:29 AM   #4
I=E/R
a7ecorsair's Avatar
Mark
I'm assuming you are talking about those small submersible pumps that sit in a sump basket. Although they are plumbed with 1 1/4" pipe, the pipe isn't at capacity. I had a two sump system in my last house that I ran all in 1 1/2" PVC and it worked great.
How likely is it that both pumps will run at the same time and if they do all that will happen is the discharge will have a little higher velocity. Will the discharge from the junction of the two pumps to the drainage ditch be level or down hill?
Feed the 1 1/4" into a 1 1/2" wye, not a tee, to joint the two systems and then feed it into 1 1/2" pipe.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
crcorn (06-14-2010)
Connecting two sump pumps mds9480 Plumbing 18 03-02-2013 09:54 AM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Different: Connecting 2 Sump pumps. JMueksch Plumbing 11 02-28-2010 02:21 PM
Basement sump pumps, 1 runs more than other cjdock Building & Construction 3 11-02-2009 06:28 AM
Question about sump pumps and check valves lennyseleven Plumbing 3 11-08-2007 10:33 AM
