2 Questions Chembond 1640/shower Drain W/o Weep Hole. - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-09-2010, 10:14 PM   #1
Smile
2 questions chembond 1640/shower drain w/o weep hole.
hi all,
I am just new on this DIY site and do have an ongoing project that hopefully I can finish within this long weekend. My question is , I plan to install a prefab plastic shower stall. Can I use chembond 1640 tile adhesive for the plastic wall? Second, the stall has its own parts such as the drain which has a 2" diameter opening. It basically fits over the drain pipe which I may have to increase/reduce for it to be use, meaning using a 2"ABS pipe for the drain reduced to 1 1/2" to the P trap. I do not have a drain with a weep hole, is this neccessary for this stall?
I appreciate any info on the matter.
slash60
slash60 is offline   Reply With Quote
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 12:49 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
bathtub drain in concrete - tail pipe questions amakarevic Plumbing 7 06-17-2008 09:50 PM
