2 Main Shutoffs For House? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-08-2013, 04:31 PM   #1
Rewards Points: 2,038
2 main shutoffs for house?
There's a short 20" pipe coming up from the ground, at the side of the house with a turn knob on it. I never knew what it was, but things work in the house so I didn't bother with it.
A plumber is here and went outside to turn off the water and I followed expecting him to go to the buried city thing out by the road. No. He turned off the water main by the faucet at the side.
Personally I think they're both the same distance. He said the faucet was so you didn't have to walk out to the road in the dark.
1983 house. Is this normal to have an extra shutoff at the side of the house? I didn't in my last house. I don't see the point.
Startingover is offline   Reply With Quote
Old 05-08-2013, 04:42 PM   #2
Electrical Enthusiast
Rewards Points: 504
Usually there will be an extra shutoff at the house, although in most of the houses I've been in the knob is on an inside wall.
Kyle_in_rure is offline   Reply With Quote
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
Startingover (05-08-2013)
Old 05-08-2013, 05:15 PM   #3
Rewards Points: 12,868
Really should have been a ball valve. Very common to have a globe valve not be able to be shut off completly.
Old 05-08-2013, 05:17 PM   #4
Old 05-08-2013, 05:28 PM   #5
thanks Kyle. Inside would have been nicer, like in the garage.
Joe, I figured you would know the reason for this. I always appreciate your help.
Old 05-08-2013, 07:34 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 352
Modern code requires a shut off inside the house now. In my area, the curb stop is owned by the city. If I turn it and it breaks I just bought a valve, including the water dept. crew to install it. Moral of the story is don't touch the street valve---
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 05-08-2013, 07:37 PM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 984
Its been required by code as long as i can remember, now you need 3 the water meter keyed valve , a second one just after your water meter in the ground with an access panel and the third outside under a bib going in to the house.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
Old 05-08-2013, 10:58 PM   #8
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Our water department puts a stop on their side and a stop on the customer side of the meter now adays. Sometimes the customer side is buried too badly by the concrete box to turn off, or the house is old enough that it doesn't have one on the customer side, and I use the city stop anyway. I use good judgement. If it doesn't turn easy, I leave it alone and tell them they need to get the city to shut it off for me if I have no other means to do so.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Old 05-08-2013, 11:29 PM   #9
eplumber,
wow. I did not know that I could be liable if I damaged the city's meter. Thanks.
Old 05-08-2013, 11:39 PM   #10
Rewards Points: 504
Yes, we have a globe valve but it only slows it down to a trickle. We have to shut it off at the street. Around here all houses have a shutoff just before the meter and a valve in the house.
Old 05-09-2013, 07:33 AM   #11
Master Plumber
Javiles's Avatar
Rewards Points: 984
Originally Posted by Startingover View Post
eplumber,
You don't have to worry about that in Florida homeowner is only responsible from the meter tail piece out,, unless you deliberately damage it
Startingover (05-09-2013)
Old 05-09-2013, 09:36 AM   #12
Plumber
Rewards Points: 352
Around here-a lot of the older homes here have meters in the basement and the line is min. 5' deep and the water line from the curb stop to the house belongs to the homeowner.
Old 05-09-2013, 01:52 PM   #13
Come to think of it, back in Indiana and Ohio, prior to 1985, we didn't have these ground level city boxes out by the road. They must have been in the basement.
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 09:15 PM
where to put main vent hohadcr Plumbing 3 03-09-2010 08:32 AM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 05:52 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
