Old 10-17-2009, 04:34 PM   #1
2 faucet shower control - Hot H20 leaking
I have a Hot water handle, a Cold water handle and a Shower diverter handle.
I have replaced the seat and the control valve on the hot water side. When I turn the water on, it is still leaking around the escutcheon. It only leaks when the hot water is turned on. The seat was just brass with no washer. Was it supposed to have one? There is a seat washer at the bottom of the control valve which I snugged tight.
Help? I don't know what else to do other than taking the tile down on the wall and buying another whole shower control body. Thanks.
John
John24689 is offline   Reply With Quote
Old 10-17-2009, 05:03 PM   #2
Residential Contractor
Always look for access from the other side of the wall before removing tile. Drywall is much easier to patch.
rselectric1 is offline   Reply With Quote
Old 10-22-2009, 02:26 PM   #3
after you remove the stem check the outer packing nut remove the packing nut grease up whole unit put some graphite packing under the packing nut snug it as so the handle will turn and leak should disappear better yet remove both stems @seats seats are in wall behind stems you will need a seat removal wrench replace stems and seats and all the trim if you want a new looking valve I used to replace everything eccept the valve body in the wall---- check everything with water on before reinstalling the trim
elcheepo is offline   Reply With Quote
Old 10-23-2009, 11:43 AM   #4
elcheepo how's about some punctuation it was like an ee cummings poem
bob22 is offline   Reply With Quote
Old 10-28-2009, 10:56 AM   #5
Sorry Bob I am new to puters, I was recently disabled and this is a new toy, I can try to help folks in best way I know how,I might take a typing class, its been a long time since I was in school, over 40 yrs and have been workng with tools not learning to type ,I am a retired master plumber and gas fitter I picked up name elcheepo from folks calling me wanting free phone advice which I gave out freely to the ones that could understand the basics
Old 10-28-2009, 05:44 PM   #6
Elcheepo,
You gave great advice, the commas and periods just help to more easily understand your ideas. Best of luck with your recovery!
Shower Faucet Leaking NightOfDiscovery Plumbing 2 08-17-2009 11:58 PM
Does not fully go from faucet to shower desimonkey Plumbing 1 04-21-2009 03:59 PM
Weird shower head leaking problem shawnst Plumbing 5 12-25-2008 12:23 PM
Leaking Shower Faucet sprtnfan Plumbing 2 12-20-2008 12:08 PM
