2 1/2 Storey Remodel 4 Bed, 1 Bath To 7 Bed, 5 Bath - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2012, 10:07 AM   #16
Thank you all.
I found out from the mayor, that they use a digital meter with a remote read out- to be located outside the front. It is 1/2 inch flow meter but has an adapter for 3/4.
I decided, I will use 3/4 for main floor and then if needed step up to 1 inch for 2nd floor and if I need to step up again to 1 1/4. My main importance is getting this first bathroom and water heater done.
I will cut the poly at 3-4', put ball valve, and make the connection to the water meter about 2-3' above the p.o.e. and use remaining poly up vertically and then make the transition to pex, to make use of extra poly (unless..?). I will strap the water meter and ball valve directly to the ICF foundation with plastic hangers and the appropriate concrete screws. (already have the screws) And finally I won't worry about that poly buldging out around the footing, `It'll probably be a closet and I'll cover it up and have an access panel for turning off the water.
qc_riderfan87 is offline   Reply With Quote
Bath Remodel & Ideas Needed - Noob Alert Fittest Kitchen & Bath Remodeling 3 08-01-2014 12:21 AM
Master bedroom and bath remodel toocheaptohire Kitchen & Bath Remodeling 1 03-06-2011 09:22 PM
Master Bath Remodel - Need Advice meth Building & Construction 8 12-07-2010 06:31 PM
Ricks bath remodel - please help RICK430 General DIY Discussions 1 05-19-2009 10:36 PM
Bath remodel wiring Nhrafan Electrical 14 03-23-2007 06:53 PM
