1970's AS Vent-Away Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2008, 08:45 PM   #1
sweaty
Rewards Points: 276
My house, built in 1976, has an American Standard Vent Away toilet, series 2003. I know this is an unusual and expensive toilet that is not made anymore. It bubbles up when flushing; I suspect because it has a standard Fluidmaster fill valve instead of the real part, which is totally different. I ordered the part ($200 and an incredible thing to look at) and am having trouble seeing where a long piece of copper tubing goes (it came with the part).
Are there instructions I could get or a diagram of how all these parts work together?
sweaty is offline   Reply With Quote
Old 08-04-2008, 11:22 AM   #2
Never heard of this toilet. I would still have a problem believing the fill-valve wold cause bubbling in the toilet though. If the bubbling is occuring in the bowl, it is more likely a venting problem. Check the link below for "some" info on your toilet. May even be your question contained there.
http://www.asktooltalk.com/questions...way_toilet.php
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 12:01 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Can I tie the sink vent into the toilet vent? domgbrown Plumbing 4 01-11-2008 05:28 PM
toilet vent problem? docholaday Plumbing 8 06-21-2007 05:05 PM
