1960 Eljer Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-10-2010, 09:20 PM   #1
Cool
1960 Eljer Toilet
I have an Eljer Toilet, with the date "Feb.12, 1960" stamped on the inside. It also has the number "2031 4" stamped on the inside.
It has a strange tank assembly (see photo). There is some sort of guide (other photo) that guides the flap so that it will work properly when flushed. This guide is broken, as you can see from the folder.
My questions are:
a) what is this part called and
b) will I be able to find a new one.
I am not in the financial position to purchase a new toilet, so I am just trying to keep this one working for another 6 months to a year. Any suggestions?
ngrasso59 is offline   Reply With Quote
Old 01-10-2010, 10:22 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
is the piece brass? how about silver solder or brazing?
plummen is offline   Reply With Quote
Old 01-10-2010, 11:37 PM   #3
That piece is the lift rod guide
You will need to go to a plumbing supply that is an eljer distributor
What part of Mass are you from?
liquidplumber is offline   Reply With Quote
Old 01-11-2010, 08:30 AM   #4
I live in Danvers, MA. It's located in eastern massachusetts on the northshore, 20 miles north of Boston.
Old 01-11-2010, 08:48 AM   #5
In response to "plummen", I was planning on giving that a try, but I would prefer a new part, as I am afraid my soldering job won't last long.
Old 01-11-2010, 11:22 AM   #6
Ellsworth Supply will have it.
1334 Dorchester Ave
Boston, MA 02122
(617) 825-5522
Not sure if there is anyone closer to you. If you call Ellsworth they can tell you.
Good luck and let us know how you make out
Old 01-11-2010, 01:23 PM   #7
Based on your last post, I Googled Eljer parts distributors and found Watertown Supply Co. (www.watertownsupply.com). They had it in stock and it cost $11.20 plus S&H.
Thanks for your help, I would not have been able to find it without you!
Old 01-11-2010, 07:48 PM   #8
Happy to help
You will receive my bill in the mail shortly
Tags
1960 , eljer , toilet tank
Eljer toilet repair KAParrish Plumbing 3 01-29-2010 08:13 AM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 08:38 PM
Eljer toilet parts Roy Rowlett Plumbing 10 01-08-2010 03:41 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
