1950s Ranch Tub - 3" Tub Drain Shoe Needed! - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-11-2008, 08:02 PM   #1
1950s ranch tub - 3" tub drain shoe needed!
We recently had some professional plumbing work done on our 1950s ranch home. The tub is orginal. The drain is 1 1/2" and they put a 2 3/4 D drain shoe (standard) on the tub. Now there is a rust ring (apparently due to some poor tub refinishing work in the past that was previously covered up by our old drain shoe) AND standing water around the drain because of some detail recessing around the drain hole on the tub. We are searching for a 3" drain shoe. Does such a thing exist? Any other ideas. Our plumber says there is no fix. HELP!!!!!
ranchgal is offline   Reply With Quote
Old 09-12-2008, 07:43 AM   #2
Whatamess
There use to be porcelain repair companies out there. Contact one and see if they can help.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 09-13-2008, 08:04 AM   #3
UPDATE: I found a 3" drain shoe with waste & over flow cover on ebay! They also have great vintage plumbing parts at rejuvenation.com. We went down to the store and all of their drain shoes measure 3".
Tags
1950s ranch , bathroom , drain shoe , plumbing , tub drain
Condensor drain Captflx HVAC 6 08-17-2008 11:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 11:35 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Rheem RXCH-A14 drain pan needed johnd393 HVAC 10 05-14-2007 01:58 PM
