1925 Basement Water Drainage Dilemna - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-27-2009, 05:51 PM   #1
Inactive
______
Last edited by Indy_Resident; 05-27-2009 at 12:19 AM. Reason: No longer wish to have online
Indy_Resident is offline   Reply With Quote
Old 04-28-2009, 06:21 AM   #2
Rewards Points: 1,538
About the flex line from the washing machine and the line from the sink are they on the wall, in the wall, or under the floor?
Your question 1. You need to figure this out. Perhaps get a plumber who has a drain pipe camera.
Your question 2. Since rainwater and ground water are draining OK you should not need to do anything here.
Also I would ...
3. Reroute the downspouts to send the water over ground and away from the house.
4. Have the washing machine drain elsewhere, not into the basement drain system.
5. Snake the floor drain that is now plugged up.
The system (perimeter drain; weeping tiles; French drain) and any appurtenant underground channels to dissipate the water keeping the basement dry should not be inundated with water from other sources such as roof or washing machine.
If you determine for a fact that there is a tunnel, which is now functioning not as a sump but rather as a drain of seemingly unlimited capacity, then you can go ahead and use it for disposal of rain water and gray water.
Caution: Do not attach an extension hose or pipe to a washing machine drain hose. If the hose that came with the machine won't reach a place where waste water can drain by gravity, you will need a tank with ejector pump. The washing machine's own drain pump doesn't have the strength to perform that task.
AllanJ is online now   Reply With Quote
stop water from leaking into basement? njhomer General DIY Discussions 5 01-26-2009 10:03 AM
Basement water meter below floor level redfox1 Plumbing 5 12-10-2008 08:20 PM
Controlling Water in basement greger Building & Construction 3 06-16-2008 05:56 PM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
basement floor water bigboyjoel Building & Construction 1 05-21-2007 04:46 PM
