180 Degree Turn In Toilet Drain - Plumbing - DIY Home Improvement | DIYChatroom
Poll: Do you think the drain setup will work?
Poll Options
Old 09-06-2011, 07:58 PM   #1
180 degree turn in toilet drain
I am re-plumbing my basement bathroom and am second guessing my plumbing route for the toilet. It currently enters at a 90, runs for 16", enters another 90, runs for 8" and takes another 90 before it runs straight into the main stack. I can easily give it a steeper slope to speed things up but am worried that solids may get stuck in the many bends. Expert opinion would be MUCH appreciated!
Below is a link to a picture of the current setup plus a floorplan for measurements:
http://reimann.files.wordpress.com/2011/09/drains1.jpg
http://reimann.files.wordpress.com/2.../floorplan.jpg
Thanks so much!
snucky is offline   Reply With Quote
Old 09-06-2011, 08:07 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 348
Not too many bends but the 3" san tee should be a combination wye & 45 and the next 90 should be a long sweep 90. I would also put a 2" vent on the toilet, but I know codes vary so you may be ok in your town
Old 09-06-2011, 08:28 PM   #3
Thanks for the quick response! I hear you on the "gentler" bends. I'll go to the hardware stores to pick up those fittings.
There is a 2" vent right behind the Wye fitting - I marked it in the image. Knowing this, would you still install an additional vent? If so, what would you replace the 90-elbow right under the toilet with?
Old 09-06-2011, 09:19 PM   #4
Also, I got the response on another board that the maximum change of direction on a horizontal run is 135 degrees. Any comment to that? Thank you!!
Old 09-07-2011, 01:10 AM   #5
Plumb or Die!
135 degrees is on a trap arm, a toilet drain can use one more 90 degree bend, for a total of 225. This includes the 90 going up.
plumber666 is offline   Reply With Quote
Old 09-07-2011, 10:16 AM   #6
225 max including the 90 that changes vertical to horizontal would still mean that I am over.
I've got 180 horizontal + 90 vertical, that's 270 total.
I'm gonna have to replumb this ... oh well - i'm so thankful i asked before I poured the cement back in!
Old 09-07-2011, 07:53 PM   #7
Plumber
Rewards Points: 348
Put the wye & 45 just upstream of the 3x2 that is shown between your feet. This will give you a straight shot to the flange location with maybe a slight offset made with a 22.
Still didn't see the toilet vent in the vent picture. You could put a 3x2 wye rolled up above the flow line of the toilet branch. Pipe it to the plumbing wall behind the toilet.
Edit: Actually, in your current configuration you have 2 90's and a 45(change the tee to a combo)= 225
Tags
angle , drain , slope , toilet
Dripping noise from toilet drain redpoint5 Plumbing 18 10-30-2013 07:23 PM
Extending a lead toilet drain. how Plumbing 4 03-31-2011 01:02 AM
toilet drain is too close to the wall in the basement Kirock17 Plumbing 15 02-24-2010 08:07 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
shower drain vs tub drain--connected to toilet???? mandalala Plumbing 2 06-24-2009 03:00 PM
