15 Year Old Kitchen Faucet - Repair Or Replace - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2011, 06:40 AM   #1
Rewards Points: 24
15 Year Old Kitchen Faucet - Repair or Replace
Our 15 year old cartridge "washerless" faucet has begun leaking cold water out of the base of the spout. I believe the faucet was manufactured by Moen.
I am wondering if there is a general rule of thumb regarding faucets, where the age of the faucet dictates that the best way to go is to replace it rather than repair it.
kc27 is offline   Reply With Quote
Old 02-02-2011, 06:48 AM   #2
Usually depends on how hard is your water. The leak is just worn O-ring seals, easily replaced. But if you have a buildup of calcium deposits, there may be corrosion or it may be very difficult to disassemble. Then it is often better to buy new.
Moen o-ring kits are available at home/hardware stores. While it is apart, replace the cartridge. Don't forget to use some plumbers grease on all rubber parts.
Old 02-02-2011, 07:50 AM   #3
Rewards Points: 352
Moen's carry a lifetime warranty on there cartridge call moen and have them ship you a new cartridge.
plumberinlaw is offline   Reply With Quote
Old 02-02-2011, 09:05 AM   #4
If you want a new faucet, this is a good excuse but I repair instead of replace when I can.
broox is offline   Reply With Quote
Old 02-18-2011, 04:53 PM   #5
Rewards Points: 24
Thanks for the replies - I ended up repairing the faucet. It took under $5, a couple of hardware store o-rings, and a pair of small springs and seats from the faucet manufacturer (turned out it is a Delta faucet).
I do have hard water, and I was surprised that there were no deposits to speak of. Everything else on the faucet is in really good shape. It appears to be built like a tank, and we still like the its looks. So after comparing the cost of a new faucet vs the minimal cost of repairs, fixing it seemed the smart way to go.
How much and how difficult to replace a kitchen light ballast? Godzealot Electrical 5 02-02-2011 07:17 PM
Plumbing Disasters Contest - Win a TOSCA Faucet for your Kitchen! Nathan Plumbing 48 07-06-2010 07:55 PM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 03:27 PM
Low water pressure on Kitchen faucet DIY_user Plumbing 3 01-08-2010 12:08 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 05:10 AM
