15,000 Gallon Concrete Reservori Leaking. - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-24-2010, 11:28 PM   #1
15,000 gallon concrete reservori leaking.
How can I seal a slow leaking, 25 year old, rebar reinforced concrete reservori? Appears leak must be in the floor of the reservori, no sign of leaks in the walls.
gosharp is offline   Reply With Quote
Old 12-25-2010, 10:31 AM   #2
Rewards Points: 1,452
1. Drain the reservoir, then repair any cracks and put waterproofing (they make a trowel-on concrete like spackling) on the inside surface.
2. Install a flexible sheet plastic liner or bladder (may or may not require draining the reservoir.
3. Don't drain the reservoir but have a not-so-deep sea diver go down and patch any cracks with hydraulic cement.
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 09:58 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
