12" On A 14" Rough-in? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-21-2011, 09:38 AM   #1
12" on a 14" rough-in?
hi. thanks for all the help y'all have given me on my other questions.
my latest problem is this: my toilet tank cracked along the side of the tank so i have to get a new toilet (can't find just the tank).
my question is that currently i have a 14" rough-in but all the new toilets are 12". can i just buy the 12" and install it? 14" are expensive and have to be special ordered - home depot does not have any.
will it just mean i'll have a larger gap behind the tank? is that a problem? is there some sort of code i'll be breaking and if something happens my insurance won't cover me?
i'm planning on buying a one-piece toilet.
thanks!
liverlipsyyz is offline   Reply With Quote
Old 06-21-2011, 03:28 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,262
Yes you can install a 12" rough toilet on 14" rough plumbing. Install a block of wood on the wall behind the tank to prevent some heavy weight from leaning back and breaking the tank. You are right that buying a 14" rough gets expensive but be glad the plumbing is not roughed at 10" like mine
Coastal South Carolina
Old 06-21-2011, 03:32 PM   #3
great. thanks. my only problem is i don't have hardly any room in front of the toilette as is and from what i understand the new install of a 12" will eat up 2 more inches in front?
Old 06-21-2011, 03:56 PM   #4
A "Handy Husband"
rjniles's Avatar
If the 2" is a problem, then bite the bullet and order the 14" rough or move the toilet flange back.
Old 06-21-2011, 05:18 PM   #5
Depending on the toilet, your front dimension will be the same. Most manufacturers use the same bowl with a bigger tank for 14" rough.
just a guy is offline   Reply With Quote
Old 06-21-2011, 05:30 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I wonder if an "offset flange adaptor" can be used to move the toilet back 2"?
XXX
Rough inspection WillK Electrical 9 01-06-2011 08:19 AM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 10:06 AM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
Replace a 10" rough in toilet with a 12" rough in Opie46 Plumbing 3 05-16-2009 11:27 AM
shower rough in frusteration! Lmiller Plumbing 5 03-13-2008 12:24 PM
