1" Water Galv Pipe Union - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-16-2012, 08:02 PM   #1
1" water galv pipe union
Put a well pump in used 4 galv pipe unions. One of them leaks and the more I tighten it the more it leaks. Will I be able to put a rubber washer in the joint where the union comes together instead of replacing the union.
Don Moore is offline   Reply With Quote
Old 07-16-2012, 08:08 PM   #2
DIY staff
Rewards Points: 7,174
Nope--it will twist out---
Usually replacement is the only option---both sides as the 'wear in' to each other and leak when mismatched--
If it is just seeping a tiny bit---adding TFE paste to the mating surfaces some times works--
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Alan (07-16-2012), Don Moore (07-18-2012)
Old 07-16-2012, 09:15 PM   #3
Rewards Points: 12,808
Here's what's going to happen with steel piping and unions.
It's going to rust out at some point, it closes up on the inside as it rust, it's going to add rust to the water which will settle on the bottom of the water heater and start to plug up the aerators on the faucets.
Also years down the road good luck trying to get them apart.
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 01:31 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-16-2009 12:09 AM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
