02-11-2013, 11:12 AM
#1
1" PEX to copper
I've recently been asked to help a coworker out that is on medical leave to install a water softener. I've worked with copper for a couple of decades on my own properties but not with PEX. I want to put copper in the wall with the bypass and shutoff valves. The supply line is 1" PEX. Can I use 3/4 copper? Is there a better way? This run adds a total of 12ft to the entire run.
02-11-2013, 11:16 AM
#2
1" PEX to copper
Ya run Pex all the way to the softner, there's nothing to be gained by using copper.
02-11-2013, 11:21 AM
#3
1" PEX to copper
How do I come out of the wall with 1" PEX. I want to make this a nice install. The softener does actually have its own bypass valve/manifold, so maybe I can just put a couple of shutoff valves. I don't mind investing in tools, wife still buying properties, I'm still the manual labor.
02-11-2013, 11:54 AM
#4
Master General ReEngineer
1" PEX to copper
Ayuh,.... 1" pex is run pretty much just like copper, only ya crimp the fittin's, insteada sweatin' 'em...
I bought This 1, 'n Love it,...
The Following User Says Thank You to Bondo For This Useful Post:
02-11-2013, 11:58 AM
#5
1" PEX to copper
Thanks fellas. Need to run down to the supply house and see what they have for fittings, HD kind of left me flat.
02-11-2013, 12:29 PM
#6
1" PEX to copper
No way to see what your seeing without a picture.
02-11-2013, 12:32 PM
#7
1" PEX to copper
Going over to take some measurements this evening. I'll take some photos and post them.
02-11-2013, 01:00 PM
#8
call me E
1" PEX to copper
Brass pex fittings are spendy- consider the high impact plastic ones.
02-11-2013, 03:14 PM
#9
Roofmaster
1" PEX to copper
Plumbing on medical leave, and then he will wonder where his job went. Oh well, at least his water will be softer.
" A lot of men build things, and a lot of things fall down "
The Following User Says Thank You to jagans For This Useful Post:
02-11-2013, 03:19 PM
#10
1" PEX to copper
Posting without comprehending, what a shame.
Co-worker out, not me, like I stated, but thanks a little for your input, your a treasure.
02-11-2013, 03:35 PM
#11
registered
1" PEX to copper
I like the pex expansion tool over the crimp tool. Pex has a memory. So once expanding and you put the fitting in. It will go back to its original size.
http://www.youtube.com/watch?v=y0UuNxhHWh8
They make cheaper expansion tools
02-11-2013, 03:37 PM
#12
1" PEX to copper
I guess another question I need to ask is do I need to stay with 1" copper on 1" PEX, or is 3/4" copper the way to go for the main line? I know there are differences in the inside diameters.
02-11-2013, 04:41 PM
#13
1" PEX to copper
3/4 will be fine.
02-12-2013, 12:38 PM
#14
1" PEX to copper
Thanks for all those that helped. Measured yesterday and it turns out its 3/4" pipe. Found a wall that runs under the pipe directly and it's going to turn out to be an extremely simple job. I'm starting to like PEX better then copper.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
