1/4" Water Line Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-14-2009, 02:18 PM   #1
Rewards Points: 640
1/4" water line install
I have a couple 1/4" water lines that come off saddle valves in my house... when looking at htem I noticed that some have that little v shaped ball soldered to the 1/4" tube and some dont... this is a compression fitting on a 1/4" copper tubing, does this little bead like v shaped circle need to be soldered to the tube or not? thanks! (I never worked with these fittings before, new to plumbing pretty much)
BlueBSH is offline   Reply With Quote
Old 12-14-2009, 03:05 PM   #2
47_47's Avatar
Rewards Points: 58
If you have compression fittings, these are ferrules and do not get soldered on. They compress to the tube when you tighten the nut, creating your seal. When installing compression fittings, bottom the tube then slide the ferrule in place and tighten the nut.
47_47 is offline   Reply With Quote
Old 12-14-2009, 03:09 PM   #3
Rewards Points: 640
thats what I thought, why in the world did the contractor when building the house solder them then
Old 12-14-2009, 03:10 PM   #4
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
They may look soldered but they probably aren't. The ferule on copper compresses so tight you cant get it off and it seems bonded to the copper sleeve.
Brik is offline   Reply With Quote
Old 12-14-2009, 03:49 PM   #5
Rewards Points: 640
In at least one of them I can see solder around the edges of it... looks just like a larger coper pipe's joint with the silverish line running around it
Old 12-15-2009, 07:44 AM   #6
When he installed them they were probably cocked and would not compress and leaked so he got fed up and soldered them once and for all.
I never use the them they seem to always cause problems somewhere down the line.
I cut in a tee with fittings and shutoff valve(ball or gate) then tie the 1/4 inch line in.
SULTINI is offline   Reply With Quote
Old 12-15-2009, 09:59 AM   #7
47_47's Avatar
Rewards Points: 58
I don't use the saddle valves either. As said above cut in a tee.
Gray PCV for water supply line - is this OK? Jim S. Plumbing 13 08-09-2010 09:20 AM
Questions about icemaker and water line options littlehoov Appliances 2 11-04-2009 11:27 AM
How to Install a Water Line to a Refrigerator With No sink yerac2003 Plumbing 6 05-07-2009 03:27 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
