1/4 Turn Shutoff Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-17-2013, 11:55 AM   #1
Rewards Points: 225
1/4 turn shutoff valve
Installed several of these in a bathroom on 1/2" copper pipe. One of the valves started to leak around the handle not the soldered connection. Replaced it. The others did not leak. After turning on one of the other valves it started to leak. Can the valve be fixed or tightened at the handle? Thanks
gt1935 is offline   Reply With Quote
Old 08-17-2013, 05:19 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Do you have a picture of the valve?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 08-17-2013, 06:40 PM   #3
DIY staff
Rewards Points: 7,174
What brand of valve----I've had trouble with the ones from Lowes--and now use only Brass Craft----
Old 08-18-2013, 09:22 AM   #4
Rewards Points: 225
Tightened the handle and the valve stopped leaking. Thanks.
Main Water Shutoff Valve Inside leaking kentifur Plumbing 6 11-03-2011 07:16 AM
installing a shutoff valve -- potential problem 19mquinn79 Plumbing 10 10-04-2011 12:23 PM
toilet shutoff valve not getting water JackyS Plumbing 4 11-23-2009 07:29 AM
Master (water) shutoff valve rmdyjoe Plumbing 7 12-05-2008 08:55 AM
