1/4 Inch Per Foot Equals ??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-23-2012, 08:11 PM   #1
1/4 inch per foot equals ???
Hi everyone.
I know my 3 inch horizontal drain has got to be at a 1/4" per foot
My question is..
What would 1/4" per foot be equal to in degrees ?
I've looked on the internet for this answer and I havent had much luck. Your help is appreciated.
kevin705 is offline   Reply With Quote
Old 02-23-2012, 08:12 PM   #2
Concrete & Masonry
Rewards Points: 620
It's extremely close to 2 degrees........
jomama45 is offline   Reply With Quote
Old 02-23-2012, 08:27 PM   #3
MarginallyQualified
Rewards Points: 2,464
I was going to start a thread about this...
I wanted to clarify the distinction between the "2%" usually referred to with longer runs and larger pipes vs the 1/4" P/LF usually referred to with shorter runs and smaller pipes.
eg: When I trench to re-route 70 linear feet of 4" main/waste pipe I'm told I can use 2% (70x12 x .02) or 16.8" because I will dearly need that 3/4" (vs 17.5").
Old 02-23-2012, 08:32 PM   #4
Concrete & Masonry
Rewards Points: 620
EDIT: After reading "Tarheel's" response, I realize I made a mistake. 1/4" per foot pitch equals 2%, NOT 2 degrees. I can't give you the exact answer off of the top of my head, but I'd say it's likely just under 1 degree.......
Hopefully someone else here can give you a better answer.
Old 02-23-2012, 08:44 PM   #5
GC/Master Plumber/Mech
Rewards Points: 560
One degree could be equal to any length depending on how far from the point of origin you are making a measurement. It is not normally a function of length.
One degree can be broken down into 60 minutes or 360 seconds.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-23-2012, 09:04 PM   #6
jschaben
Rewards Points: 502
Originally Posted by kevin705 View Post
Hi everyone.
My question is..
Hi Kevin: works out to 1.2. It would be the inverse tangent of .25/12 but I just drew it out in DeltaCad and let it figure out the math
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 02-23-2012, 10:40 PM   #7
Thanks for the answers.
If your curious , any levels that I can find find have an auto adjust for the degrees.
And for this length of pipe it'll be helpful to know what I can set it at.
Thanks Again.
Old 02-23-2012, 11:00 PM   #8
MarginallyQualified
I don't know anything about this whiz-bang gizmo you have, but...
If Point "A" = X" (below some known grade level or such)...
then Point "B" 100 linear feet away MUST be 24" shallower than X.
(100 x 12" x .02)
For the 1/4" P/lf method... 100' x .25" per = 25" shallower.
If you don't have a transit...
try some clear vinyl hose with water in it.
after an annoying ad:
http://www.deckmagazine.com/article/64.html
Old 02-23-2012, 11:18 PM   #9
Doing it myself
Alan's Avatar
Rewards Points: 2,086
To be a little more accurate :
1.193489423982035
Journeyman Plumber
Old 02-24-2012, 07:27 AM   #10
Rewards Points: 636
go to home depot and buy a husky plumbers level it has 1/8, 1/4, 3/8, rise marks on it just
make sure you use it right or your pipe will be going the wrong way
http://www.homedepot.com/Tools-Hardw...&storeId=10051
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-24-2012, 08:03 AM   #11
Rewards Points: 120
Tape a shim (1" in this case) on one end of a 4' level.
Old 02-24-2012, 08:09 AM   #12
Rewards Points: 150
Or, I've seen guys take a 4' level and tape a 1" block to the end of it.
edit: ^^^ he beat me.
psilva8 is offline   Reply With Quote
Old 02-24-2012, 06:49 PM   #13
KemoSabe
loneframer's Avatar
I have two different sizes of these levels. They convert from degrees, % and ?/12(for roof pitch). A little fun and you can convert anything you want.
http://www.sears.com/shc/s/search_10...el%20craftsman
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
5/8 water meter with a 1 inch servise line ????? ogoz23 Plumbing 11 02-04-2012 10:35 PM
Size of framing for piller that will have 6 inch tile on it. jpeake General DIY Discussions 3 12-05-2010 08:40 PM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 11:19 AM
bath floor nailfun Plumbing 5 02-20-2007 10:35 PM
24 inch to 16 inch Centers dsearles Building & Construction 3 11-30-2005 10:20 PM
