1.25-1.50" Transition - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2014, 01:03 PM   #1
In a little over my head
Rewards Points: 706
1.25-1.50" transition
I'm installing a new Delta faucet into a new construction bathroom sink. I was told to use a Fernco between the wall and P-trap. (??) The drain tailpiece is 1.25". I have 1.5" PVC coming out of the wall. Would you use a size adapting washer at the tailpiece and run a 1.5" P-trap to the wall with a 1.5 Fernco, or 1.25" P-trap to a 1.25-1.5 Fernco?
Or doesn't it matter? Or is there a better way? Thanks!
ratherbefishing is offline   Reply With Quote
Old 05-09-2014, 02:21 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 684
I use a 1.5" trap adapt. 1.5" trap with a reducing washer to receive the lav's tailpiece.
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
plummen (05-09-2014), ratherbefishing (05-09-2014), SHR Plumber (05-09-2014)
Old 05-09-2014, 03:48 PM   #3
Rewards Points: 706
Thanks, Eplumb. Is the "1.5" trap adapt" a rubber Fernco,or something else?
Old 05-09-2014, 04:05 PM   #4
Owner
LateralConcepts's Avatar
Not a fernco. It's like this: http://www.zoro.com/g/00023637/k-G30...FQcSMwodZQEANA
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
Old 05-09-2014, 08:39 PM   #5
Rewards Points: 706
Got it. That looks way better than a Fernco. I'll go shopping tomorrow. Thanx!
What to do with this transition? ees789 Flooring 10 12-12-2012 07:00 PM
Transition from Vinyl to Wood Question petros151 Flooring 3 02-16-2012 11:42 AM
door jamb cut over transition rtoni Building & Construction 4 10-28-2011 03:50 PM
Tiling entryway - proper transition for this scenario? Scott99999 Flooring 5 12-22-2009 12:12 AM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 11:21 AM
