1/2" Soft Copper Pipe Is Stuck - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2009, 01:29 PM   #1
1/2" soft copper pipe is stuck
I woke up this morning with a broken pipe under my house. The supply line to the toilet had ruptured right where it penetrates the floor and against an exterior wall. I turned off the water supply but unfortunately there was no cutoff for this supply line. I installed a cutoff so I could restore water to the rest of the house. Now the problem! After disconnecting the fittings from the toilet and cutting the pipe under the house, I can't pull the remaining pipe out from either end. I have tried channel lock pliers but it won't budge. Any ideas would be greatly appreciated!
Thanks,
Jim
JT61 is offline   Reply With Quote
Old 02-11-2009, 01:54 PM   #2
Remodeling Contractor
Try a jig saw with a metal blade and cut a slot through the pipe so it can fold up into itself.
Old 02-11-2009, 02:12 PM   #3
Thanks Bob,
I will give that a try and let you know!
Old 02-11-2009, 03:07 PM   #4
Bob,
I can't get the saw close enough to the pipe as the pipe is run right up against the exterior wall and it is broken off flush with the subfloor!
Old 02-11-2009, 03:15 PM   #5
Rewards Points: 1,910
Pound it out with a hammer and suitable drive pin (old screwdriver, piece of 1/2" rebar or anything that fits that you can pound on) from above.
Old 02-11-2009, 03:30 PM   #6
47_47's Avatar
Rewards Points: 44
Post some pictures and don't start trying things blindly. I've created more headaches by rushing into a job like this.
47_47 is offline   Reply With Quote
can you bury copper pipe ? amakarevic Plumbing 12 08-05-2009 07:25 PM
Allen screw and copper pipe? dolvio Plumbing 1 02-09-2009 07:38 PM
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 10:43 PM
nicked copper pipe analogmusicman Plumbing 3 07-28-2008 09:54 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 11:55 AM
