Old 09-17-2006, 10:48 PM   #1
1/2" Self Tapping Valve
I am adding a pedestal sing in a new bathroom I adding to my home. I was wondering if a self-tapping valve is an acceptable way of connectong to the existing water supply. I have 1/2" copper lines in the wall directly behind where I am placing the sink. Any suggestions would be appreciated!
Brad
wbjdmd is offline   Reply With Quote
Old 09-17-2006, 10:59 PM   #2
World famous jerk.
You're not going to find a piercing valve suitably sized to provide the volume necessary for a ped sink.
In a word, piercing valves 'suck'. They generally always begin to leak, sooner or later. There is no real reason, other than your own lack of skill or confidence, that you need to hot tap a line inside a dwelling.
Put in a real tee and a valve.
mdshunk is offline   Reply With Quote
Old 09-17-2006, 11:01 PM   #3
That's pretty much what I fugured, I guess I just wanted someone else to tell me that. I'll probably just cut and solder in a t-valve!
ball valve leaking bwall Plumbing 10 12-31-2012 08:25 PM
Toilet valve replacement? steve771 Plumbing 18 07-10-2007 11:50 AM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 09:23 PM
