1/2 Pvc Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2012, 07:32 PM   #1
Retired NYPD
1/2 pvc pipe
I am thinnking of using 1/2 pvc pipe to run new water lines to a bsmt. kitchen sink. I want to use existing 3/8 shutoff valves that are under my slop sink. They are about 35 ft. away from new sink. Is it doable to connect to the 3/8 valves with a tee fitting, and then connect an adapter for the pvc?
FrankLa is offline   Reply With Quote
Old 01-27-2012, 07:35 PM   #2
Rewards Points: 582
i think you mean cpvc......but I really would do pex if i were you...Iwould run 1/2 pipe to other sink tapped off 1/2"piping not 3/8...
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (01-27-2012)
Old 01-27-2012, 07:42 PM   #3
Retired NYPD
It is not 3/8 piping, it is a 3/8 valve shutoff under the sink. I want to put a tee on the valve and then connect the 1/2 cpvc to an adapter for the 3/8 valve.
Old 01-27-2012, 07:54 PM   #4
Rewards Points: 582
if you do that you are still feeding off a 3/8 " port....not 1/2" as intented.... maybe Iam missing something...if you shut off 3/8 valve would it control both sinks????
Old 01-27-2012, 08:04 PM   #5
Retired NYPD
yes. the adapter is for 3/8 to 1/2 cpvc. I would put another shutoff at the other end for hot and cold.
Old 01-27-2012, 08:15 PM   #6
Rewards Points: 582
thats what i thougth.... i can't ok this install because its not right...off the record will it work yes....would it past code no ...
FrankLa (01-27-2012)
Old 01-27-2012, 08:22 PM   #7
Rewards Points: 13,960
Far better to have you main long line run with 3/4 if you expect to have an presuure and flow at the end of the line then step it down at the shut offs.
Your decription does not make since to me.
Wheres the hot water line? Your going to have to run two lines one for hot and one for cold.
If your plan is to try and use old shut off valves, forget it. They go bad over time. They make CPVC to 3/8 compression shutoffs that just glue on.
FrankLa (01-28-2012)
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 12:31 PM
Working with B-Vent pipe for WH vent BobN HVAC 16 01-25-2012 11:58 PM
Well pipe access shutdown HomerRepair Plumbing 6 03-08-2011 09:22 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
