1/2" Pipe Fittings Don't Fit Old Pipe- PLEASE HELP - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2009, 11:17 PM   #1
1/2" pipe fittings don't fit old pipe- PLEASE HELP
So, I'm replacing a leaky supply line in my kitchen sink; it's 1/2 copper pipe, I have the new stubs sweated together, the old pipe cut and cleaned, everything's ready to go, except... the coupling won't fit!
I measured a piece of the old pipe I cut out, and the diameter is just slightly bigger than the new pipe; about one wall thickness extra, barely (but definitely) too big for the coupling to fit over.
Here's the really weird part: I un-sweated the old pipe from the elbow it had, thinking I could use the elbow on the cut I'd made, and now I have a 6" length of the old pipe. The end that was sweated into the elbow fits fine into a 1/2" coupling or elbow, but the other end (where I made the cut) is too big! Is it possible the pipe swelled over time? It is the hot water supply, if that would make a difference, and it's probably 50 years old...
Has anyone here encountered this problem before, and more importantly, does anyone know a work-around? I'm calling the specialty plumbing supply tomorrow (it's 11 pm and I've given up on having water tonight, or most of the day tomorrow at this point), and I'd like to know what to ask for...
carjack is offline   Reply With Quote
Old 05-21-2009, 03:22 AM   #2
Rewards Points: 562
just guessing,but the too big comes from being frozen at one time or another. Nothing fits if thats the case,,,buy a new chunk and start over.
4just1don is offline   Reply With Quote
help re-installing shower head 1/2" pipe extension cbons Plumbing 2 04-15-2009 05:06 PM
1/2" soft copper pipe is stuck JT61 Plumbing 5 02-11-2009 02:30 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
