1/2 Pex To DELTA Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-01-2012, 06:44 PM   #1
Rewards Points: 12
1/2 pex to DELTA shower
I`m putting in a new shower it has 3/4 supply hook ups.Will 1/2 pex feed enough water to this unit? Thanks
ndmick is offline   Reply With Quote
Old 06-01-2012, 07:00 PM   #2
Rewards Points: 12,794
It will but if somehow you could tie into the 3/4" lines instead it would give you more flow. More flow= more pressure.
Old 06-01-2012, 07:01 PM   #3
Rewards Points: 6,652
3/4 Pex, with 3/4 to 1/2 Sharkbite reducer would work.
Old 06-01-2012, 07:09 PM   #4
Rewards Points: 12
Manifold
My house has 1 of those manifold pex systems and inless I tap into it before the manifold every other line that comes out is 1/2".Just wondering if I run 1 line will it be enough.I would really like it to work correct.
Old 06-01-2012, 08:01 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 348
What is the gpm output of your shower?
Old 06-01-2012, 09:51 PM   #6
Rewards Points: 582
most faucets with 3/4 feeds should stay 3/4 to provide volume so the faucet can operate as it is suppose to ..imo 1/2" supply would not work....its 3/4 for a reason...
The Following User Says Thank You to ben's plumbing For This Useful Post:
VIPlumber (06-01-2012)
Old 06-02-2012, 08:32 PM   #7
Rewards Points: 12
This is probably a stupid question ,but,could I run two 1/2" pex lines from my manifold over too my shower and then tee them to 3/4" please any help would be app.
Old 06-02-2012, 09:46 PM   #8
Plumber
Rewards Points: 348
Yes you could but why not cut in a 3/4" tee before the manifold and run just one line instead?
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (06-02-2012), VIPlumber (06-03-2012)
Old 06-03-2012, 02:00 AM   #9
Homerepairguy's Avatar
Rewards Points: 990
ndmick,
Since the link you provided shows a shower only with no tub, TheEplumber's question above is a good one.
Current standards limit the maximum water flow of shower heads to 2.5 gpm. 1/2 inch PEX tubing has a flow rate of 6 gpm but that's for the tubing only. If you use crimp or cinch fittings, the inside diameter of the fittings will be smaller so the flow rate will be less. But it will still be higher than 2.5 gpm and high enough even if you remove the flow constrictor from the shower head.
The Wirsbo/Uponor PEX system uses the expansion method for fittings so the ID of the fittings will be about the same as the 1/2 inch tubing. This should give you about 6 gpm.
Any PEX system using 1/2" tubing will give you more flow than one shower head needs.
$.02,
HRG
Homerepairguy is offline   Reply With Quote
Old 06-03-2012, 08:14 AM   #10
Rewards Points: 12
Thanks too all that responded.Eplumber that is what I thought I might do ,but, just wanted to ask if the other way would work.Homerepairguy thank you for the great answer I thought 1/2 might be enough.being its a shower only.THANKS AGAIN TO ALL
Delta scald guard shower valve leak pdamania Plumbing 1 03-08-2011 06:45 PM
Delta Ball Joint shower arm adapter??? nic3456 Plumbing 3 11-10-2010 11:01 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Delta Jetted Shower - install problems . . . Eusibius2 Plumbing 7 11-13-2009 12:21 AM
Low Water Pressure Delta Single Handle Shower Model 602 rckeagle Plumbing 2 07-24-2009 03:11 PM
