1/2 Inch Moen Cartridge Stuck In Back Of Pipe. Please Help! - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-28-2013, 10:17 AM   #1
1/2 inch moen cartridge stuck in back of pipe. Please help!
I tried to remove my Moen cartridge due to a leak. The middle cylinder came out and left the plastic cartridge stuck in the pipe. I tried and easy out and threaded tap. No luck. What I am left with is about an inch of cartridge (becasue the rest broke off clean using the easy out) wrapped around the little pipe in the back of the valve body. I am at a loss. I am afraid to try and chip it out in fear I may damage the pipe it's wrapped around. The calcium build up is what has it stuck in there I think.
Jcantie is offline   Reply With Quote
Old 07-28-2013, 10:28 AM   #2
This is what's left.
1/2 inch moen cartridge stuck in back of pipe.  Please help!-moen.jpg
Old 07-28-2013, 10:34 AM   #3
Rewards Points: 159
I just went through this same thing myself. After it broke inside the housing I had to break it apart piece by piece using a screwdriver. I carefully placed the screwdriver tip between the housing and the remaining cartridge and pried inward to break off as much as I could at a time being careful not to score the brass housing. After a lot of work I finally got it out of there. Mine had an O ring on the back that was keeping it from being pulled out as well as the calcium and corrosion. Once removed I turned the water back on briefly to flush out the housing, smoothed the inside of the housing with some steel wool, and then installed the new cartridge. No problems since. Hope this helps.
kb3ca is offline   Reply With Quote
The Following User Says Thank You to kb3ca For This Useful Post:
Jcantie (07-28-2013)
Old 07-28-2013, 10:40 AM   #4
Thank you. How did you not damage the O ring?
Old 07-28-2013, 11:15 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 354
The o-ring is part of the new cartridge so don't bother saving it- but it has to come out
Read this thread and see if there's any useful info for you-
replacing shower cartridge
Old 07-28-2013, 11:32 AM   #6
Rewards Points: 1,706
I drilled one out using a carbon drill that was smaller then the outside brass.
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 06:27 PM
Sewer Back Up/ Pipe Relining Question newbinca Plumbing 9 05-10-2013 01:23 PM
Sump Pump Discharge and drain Back dukeboy633 Plumbing 7 04-26-2013 02:19 PM
New Moen Cartridge leaks Firemanjl Plumbing 4 07-21-2011 11:53 AM
4 inch drain pipe econdave Building & Construction 7 06-04-2009 12:57 PM
