Is 1/2" CPVC Too Restrictive? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2012, 08:49 PM   #1
Is 1/2" CPVC too restrictive?
Recently purchased a new (to me) house. It was originally built in 1955. Between then and now the previous owner redid 90% of the plumbing.
I recently overseeded my lawn and to my surprise, I do not have enough flow to run even 2 small impact sprinklers. The second sprinkler will only squirt out water 6" and won't rotate.
Upon further investigation, the main water line coming in goes through the meter and regulator, and right after that goes from 3/4" to 1/2". Then it splits off, with a 1/2" line going to my water heater and then the other 1/2" goes off to supply the rest of my cold water circuit.
I'm fortunate enough that most of the fixtures that I'd care about pressure about (basically everything except the toilets) are relatively close to each other, and are easily accessible. So replumbing it all wouldn't cost too much.... but the question is would I gain by replacing it with 3/4" or do I have an internal restriction elsewhere?
danhr is offline   Reply With Quote
Old 09-20-2012, 08:55 PM   #2
Rewards Points: 582
running 3/4 pipe will get you more volume ..I would run 3/4 to hot water tank..3/4 as far as you can on cold water side branching off with 1/2" to fixtures..with out see layout I would also run 3/4 to sprinklers.....make sure pressure regulator it working..ben
Old 09-20-2012, 08:58 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 684
Plumbers use sizing tables based on delivery pressure, fixture demand, etc. But as a rule of thumb- no more then 2 fixtures on a 1/2" line. 3/4" to and out the water heater.
You should check your pressure too- 60lbs is about right
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (09-20-2012)
Old 09-20-2012, 09:00 PM   #4
Plumber
Rewards Points: 684
I like how you think Ben
Old 09-20-2012, 09:03 PM   #5
Rewards Points: 582
same here ... great minds think alike.....
Old 09-20-2012, 09:26 PM   #6
I'm glad I'm not a total idiot.... that was actually the general way I was thinking of running it all.
So running the entire house (fwiw, 2 sinks, 2 showers, 2 toilets, 2 spickets) off a main reduced down to 1/2 = .... correct?
Old 09-20-2012, 09:36 PM   #7
Rewards Points: 582
yep..need more volume..if you run 3/4 to water heater..make sure you run 3/4 out from hot side as far as you can again branching off with 1/2 to fixtures....adding some 3/4 will help alot...
Help with running new CPVC water lines. Integraoligist Plumbing 0 03-05-2012 02:17 PM
Water Heater Connections (CPVC) Pittsville Plumbing 16 01-21-2012 08:02 AM
CPVC Installation Questions Pittsville Plumbing 24 01-30-2011 08:38 PM
Connecting Water Filter Housing to CPVC Pittsville Plumbing 7 01-20-2011 02:01 PM
CPVC tubing and angle stop valve Wiscbldr Building & Construction 1 01-14-2011 10:11 AM
