1/2 Copper Pipe "l" Or "m" - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-05-2008, 11:52 AM   #1
1/2 copper pipe "l" or "m"
Which kind of pipe is used for hot/cold water supply? I happen to have a lot of the red (which I believe is "m"), left over from another project. Not sure it matters, but I am in PA.
SR996 is offline   Reply With Quote
Old 12-05-2008, 12:17 PM   #2
Red is the color coding for type M copper. This is the thinnest type and is normally used inside the home. Type L is colored blue and can be used inside or out. Type K is green and the thickest type for water lines and is generally used for water mains and underground use. Unless your local Code calls for another type, M should be no problem.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-05-2008, 03:51 PM   #3
Rewards Points: 410
I thought it was everywhere, but here only type "L" (blue) copper can be used for domestic water and "M" only allowed in a houses heating system.
Piedmont is offline   Reply With Quote
Old 12-05-2008, 06:35 PM   #4
Rewards Points: 2,906
I'd question that since it's common to see 1/2 inch Type M copper pipe for sale in home centers, but I have yet to see a hot water heating system that uses 1/2 inch copper pipe. So far as I know, hot water heating systems will typically use 3/4 inch piping (copper or iron).
My understanding is that Type M is used for both hot and cold water supply piping in residential buildings (houses) whereas Type L is used for hot and cold water supply piping in commercial buildings (including apartment blocks). I know that ALL of the 60 year old copper piping I take out of my apartment block is Type L. From what I know, Type M can be used for hot water heating systems in both residential and commercial buildings.
Nestor_Kelebay is offline   Reply With Quote
can you bury copper pipe ? amakarevic Plumbing 12 08-05-2009 06:25 PM
nicked copper pipe analogmusicman Plumbing 3 07-28-2008 08:54 PM
misfits b/ween copper supply pipe and fittings amakarevic Plumbing 8 06-10-2008 08:39 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 10:55 AM
Can I Extend the 3/4" Copper Pipe? froddan Plumbing 2 07-23-2007 04:03 PM
