1/2" Copper Gas Pipe With 5/8" OD - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2013, 07:00 AM   #1
1/2" Copper Gas Pipe with 5/8" OD
Hi All,
I made a rookie mistake and ran a 1/2" copper gas line (inner diameter) that has a 5/8" outer diameter.
I plan on flaring my pipe and using a flare nut, however the pipe won't fit through my 1/2" flare nut.
If I use a 5/8" flare nut, will the threads also be 5/8" ? I need to connect the pipe to an existing 1/2" OD shut off valve.
Is there such thing as a 5/8" flare nut that has 1/2" threads?
bergsj is offline   Reply With Quote
Old 01-26-2013, 09:34 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 328
Nope,... Dependin' on how ya look at it, ya ran the wrong size line, or ya just gotta Adapt what you've got, to what ya need....
Btw,... Most flarin' tools, Don't do 5/8" copper tubin'....
Old 01-26-2013, 09:45 AM   #3
Rewards Points: 12,790
Your not trying to flare hard copper tubing are you?
Is this tubing going behind a wall? Any place I've lived you have to use steel pipe not copper.
Also In a lot of places it's againt the law for a home owner to even work on gas lines.
How To Bring Copper Pipe Through Concrete Block Starlight Plumbing 14 12-15-2012 08:48 AM
Copper Pipe Water Lines trophywalleye Plumbing 3 03-04-2011 09:44 PM
PVC air admittance value and copper waste pipe diy888 Plumbing 2 02-16-2011 08:48 AM
Copper to Black Pipe Gas Connection dwolek HVAC 1 03-15-2010 06:02 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 11:55 AM
