-   -   1/2" Copper Gas Pipe with 5/8" OD (http://www.diychatroom.com/f7/1-2-copper-gas-pipe-5-8-od-170152/)
bergsj 01-26-2013 06:00 AM
Hi All,
I made a rookie mistake and ran a 1/2" copper gas line (inner diameter) that has a 5/8" outer diameter.
I plan on flaring my pipe and using a flare nut, however the pipe won't fit through my 1/2" flare nut.
If I use a 5/8" flare nut, will the threads also be 5/8" ? I need to connect the pipe to an existing 1/2" OD shut off valve.
Is there such thing as a 5/8" flare nut that has 1/2" threads?
Bondo 01-26-2013 08:34 AM
Nope,... Dependin' on how ya look at it, ya ran the wrong size line, or ya just gotta Adapt what you've got, to what ya need....
Btw,... Most flarin' tools, Don't do 5/8" copper tubin'....
joecaption 01-26-2013 08:45 AM
Your not trying to flare hard copper tubing are you?
Is this tubing going behind a wall? Any place I've lived you have to use steel pipe not copper.
Also In a lot of places it's againt the law for a home owner to even work on gas lines.
