Old 02-13-2010, 04:49 PM   #1
1/2" copper feeding 2 floors
I am renovating my house and I have 1/2 copper that feeds the 2nd floor shower and 3rd floor apartment with shower, kitchen, dishwasher and washing machine. Do I need a larger line going to the 2nd or 3rd floor? I was going to add a pressure booster in the basement. Will that suffice?
Another question is I am replacing my shower faucets with balanced pressure devices. If the pressure is not even with myhot and cold will I have a problem? Currently I have to turn the hot all the way open and the cold just a little bit. Increasing the temp at the hot water tank does not seem to make a difference.
Thanks!
crazychef55 is offline   Reply With Quote
Old 03-26-2010, 05:57 PM   #2
Preferably you would want 1 inch from the main, 3/4 inch in the house then 1/2 inch branching off to the fixtures. This keeps the pressure more ocnsistant when multiple fixtures are in use. Less liklihood of scalding hot showeer when toilet is flushed. Mine has 1/2 throughout form the main probably installed by the original buider who did averything himself apparently without researching first. I have lived with it for 14 years but would eventually like to replace with 3/4 PEX to improve pressure.
Jim F is offline   Reply With Quote
Old 03-26-2010, 07:55 PM   #3
Doing it myself
Alan's Avatar
Sizing is based on fixture units, incoming pressure and developed length of your system.
We would "normally" run a 3/4" hot and cold line in that situation
Pressure balance devices balance the pressure on their own. You should have the same amount of pressure throughout the system, however.
Journeyman Plumber
Slip-on diverter with less than an inch of 1/2" copper nipple out of the wall jamesm113 Plumbing 3 07-24-2009 12:23 PM
1/2" OD copper to 1/2" nominal with T connector? bobpiker Plumbing 9 02-26-2009 12:06 PM
1/2" soft copper pipe is stuck JT61 Plumbing 5 02-11-2009 03:30 PM
Copper pipe size question greymous Plumbing 18 01-30-2009 05:02 PM
Hardwood floors installed over 1/2" and 5/8" subfloor interplexr Flooring 1 01-25-2009 02:00 PM
