1/2 Bath Design Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-26-2009, 09:49 PM   #1
1/2 bath Design Help
I have some space that I am thinking about adding a 1/2 bath.
The space is 5'5" long and 36 wide. The door will be at the long end and not at the side. Is it possible to have a toilet and sink in the room and still be within specs???
thanks
something like this----- http://img33.imageshack.us/my.php?image=4746l.jpg
kw151002 is offline   Reply With Quote
Old 05-27-2009, 06:50 AM   #2
IRC R306.1 shows 21" in front of toilet/sink, 4" between toilet tank edge and next fixture on sides. Check local code.
Old 05-27-2009, 07:18 AM   #3
thanks - is there a spec how much space between sink and the opposite wall?
Old 05-27-2009, 08:28 AM   #4
Rewards Points: 346
I don't know if it would meet code today but my mom's house has a 1/2 bath in a 28" x 42" room. It is tight but it works... The sink is tiny and when you are seated your knees are under the sink competing with the trap and supply lines for space.
RegeSullivan is offline   Reply With Quote
Old 05-27-2009, 10:04 AM   #5
Your toilet would have to be against the end wall not a side wall to meet code clearances and I doubt you will find a sink that extends from the wall less than 15" to meet clearance requirements.
hayewe farm is offline   Reply With Quote
Old 05-27-2009, 10:37 AM   #6
Newbie Bill
Rewards Points: 520
Hayewe farm may be correct on this. But don't let that stop you. Just be creative.
Make sure you find out the local code requirements and go from there.
I can visualize the toilet at the far end of the space with a small rectangular sink along the side. Ideally, a sliding pocket door would be best.
First stop is to check out your local codes.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 05-27-2009, 10:48 AM   #7
You might want to check with RV parts suppliers, they may carry a sink small enough to allow proper clearances.
Old 10-09-2010, 06:21 AM   #8
can i install a toilet with only 26" clearance accros
rustyrobo is offline   Reply With Quote
Old 10-09-2010, 08:16 AM   #9
Just call me Andrew
Rewards Points: 1,020
These sinks are TINY!
http://www.homedepot.com/Whites/Comp...atalogId=10053
And what about a wall-hung toilet where the tank is inside the wall? I don't really know anything about them...
Andrew
secutanudu is offline   Reply With Quote
bath med cabinet design questions wombosi Carpentry 6 12-12-2008 02:06 PM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 06:45 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
Small 1/2 BATH Design Issues Designman20 Plumbing 5 10-09-2007 12:44 PM
